Hanging idle. 01 SS
Got the new nitto 555s on and man she handels like on rails! Got new iridium plugs and wires as well, and runs so pure now. But the idle is hanging at 1k rpm. But ideal normal at start up until I drive it around. It just started after picking it up from Firestone shop today. I haven't had a chance to investigate but hopefully tomarrow. Any ideals would be great help for a good starting place. Thanks!!
Try resetting your TPS
Unplug your TPS (Throttle Positioning Sensor)
Turn your key to the second position right before cranking (keep it on for 30 seconds)
Turn key off and plug your TPS back in
Turn car on
See if that makes a difference
Turn car on
No I didn't try the reset. But I was like well **** it ,i minus well buy a new one since its 14 years old. I haven't even got to drive it yet since I installed the new one. But when I do this weekend, I'll update with results. Thank you for the suggestion. If it don't fix it maybe I'll get a new iac
Lol. But it did fix it, no more hanging idle. Just thought I would throw this out there because you were correct about the hanging idle problem, sometimes I hear a bit of a ticking sound at idle. Could that be a lifter or just something with the belts/pullys. I guess I could run it threw a few exercises "hot/cold/ rev" to see when it is more present or none existent at different point and times. Thank you for your help. "Ho" yea also I have a bit of a gurgle then a slight Pop "sound when depressing the clutch at higher RPMs and up shifting. The car has longtub headers and high flow cats 3 inch exhaust pipes. I looked for leaks up and down but no signe of leaking exhaust. This is my first ls1 car so I'm just figuring out its character/ pros & cons
