98 to 99-02 swap bcm/ecu/ignition
Need some input I did a 98 swap 5 years ago now im rewriring car for the 99-02 harness I got a 2000 Camaro ecu an engine harness then I got 99 Camaro interior harness can I use my 98 body control
moldue with my 98 steering coulum igition/key an everything work or do I need to get the 99 column igition/key with 99
Key an bcm
Key an bcm
I'm not sure on that I think they changed the way the communicate on the BUS 98 was the last year for a lot of things. I repined a 1998 harness to a 99 wont do that ever again what a rats nest.
