lunati cams
lunati cams
i have a quistion what is the best lunati cam are they any good and why does the advertised duration say higher than the actual duration. heres a couple of links to ones i was checking out are they better than tsp's ms3? how do the Howard cams work are they actual that high duration or is there a actual number and thats just the advertised number. and also what is the biggest cam you can shove in there before running into problems with clearance.
http://www.ebay.com/itm/Lunati-Voodo...dRErcb&vxp=mtr
http://www.ebay.com/itm/HOWARDS-GM-C...1WFUP5&vxp=mtr
OK I add an aliteriate moment lol. But now a new problem arose I bought the ms3 cam, comp cams 7.400" pushrods, lunati springs and retainers, as well as a trunion kit. But a friend of mine said that the 7.400" rods will be to short but another said to long but a fourm member said they are fine so which is it. Also do I really need a stall converter its a A4 trans. Or can I suffer with the stock one till I can fine one for a reasonable price.
LS1Tech Administrator
Received 1,795 Likes
Additionally, idle tuning is already more of a challenge with a big cam in an A4 car (vs. M6); sticking with the stock stall will make it even harder to get decent idle transition from park to gear, as well as in-gear idle speed. That cam plus a stock stall speed is just a bad setup to drive on the street OR for track performance IMO.
I think you'd benefit quite a bit from doing a lot more research before tearing into this car, or make sure you have a knowledgeable friend helping you.
OK thanks for the reply is there an methods of checking the length with out the tool or is that the best way also why wouldn't the stock size be big enough I asked a guy who had the same cam he said it would or does it all depend every engine is different o guess. Also what stall would you recommend like a 3000 or something what is stock like 2000. According to comp they recommend a stall 2000 or higher.
