Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Shark Gray 2000 SS build
Old 01-26-2018, 12:22 PM
LaBLKv6Z's Avatar
Scored a set of Fikse FM5's wheels from a fellow Louisiana ls1tech member, they just needed to be refinished.
Test fitting the rears.
Stripping the clear coat.
Wet sanding, removing the machine finish.
All polished up.
315/35/17 Nitto 555Rs
Old 01-26-2018, 12:42 PM
AnotherWs6's Avatar
Nice job on the wheels. So you're not running DR's anymore or are those tires for the front?
The following users liked this post:
Jessemess (11-10-2020)
Old 01-26-2018, 12:49 PM
LaBLKv6Z's Avatar
Thanks, it took about 6 hours per wheel. I'm running the drag radial 555R's in the rear and street 555's in the front.
Old 01-26-2018, 12:50 PM
HCI2000SS's Avatar
So you gained about 30 hp just with a dyno tune over the Frost tune?
Old 01-26-2018, 12:53 PM
LaBLKv6Z's Avatar
While dyno tuning the car, we noticed that it was passing oil on decel. After researching I found that I forgot to seal my rocker arm bolts since these heads are ported. Easy fix.
First time auto crossing in general, it was a blast. Car handled very well, even on drag radials.
Old 01-26-2018, 01:04 PM
LaBLKv6Z's Avatar
Yeah, I was skeptical but the Frost tune was very rich. This was on a DynoCom dyno also.
Old 01-26-2018, 01:13 PM
HCI2000SS's Avatar
Gotcha. Just goes to show how important a good custom tune is.
Old 01-26-2018, 05:25 PM
LaBLKv6Z's Avatar
For sure, especially with a HCI setup.
Old 01-26-2018, 06:01 PM
clinebarger's Avatar
Love the color, Great looking ride man!!
Old 01-27-2018, 03:12 PM
LaBLKv6Z's Avatar
Thanks man.
Old 01-28-2018, 02:12 PM
Your welcome, What headlights are those? Do you like them?
Mine are foggy & need replaced.....
Edit.....I think I'll start a thread on my car, Thanks for the inspiration!
LaBLKv6Z (05-24-2023)
Old 01-28-2018, 03:02 PM
  #32
LaBLKv6Z's Avatar
Cool deal, my head lamps are Depo 335-1122P-US2. Previous owner installed them but I had the same set on a 98 Camaro I had.
Old 01-28-2018, 03:24 PM
  #33
LaBLKv6Z's Avatar
Put it on the scale after doing the front bumper support, rear seat, and radio delete.
Unfortunately had a full tank of gas. Not bad for a T-top car.
I drove it for a few months without the front grille just to change up the look.
Old 01-28-2018, 03:59 PM
  #34
LaBLKv6Z's Avatar
Car is on Koni Yellows and Vogland springs. I removed the rear isolators and SS bumpstop spacers. Had to roll the rear fender lips.
Entered it into the local Pepboy's dyno challenge and won highest horsepower NA.
Car put down 438/380 on this dyno, IATs were in the upper 90s.
Added a 67 SS emblem to the grille. Also stripped the black side marker and tail lights for a cleaner look.
Looks a lot better without the rake.
Local car meet with fellow LS1tech member.
Back at the track chasing an 11 sec run.
Old 01-30-2018, 12:31 PM
  #35
LaBLKv6Z's Avatar
The Speed Engineering Dual exhaust kit was being pushed into my fuel tank by the rear axle. It was also loud and droned at HWY speeds. I pulled off the piping after the x-pipe and sold it. Then I bought (2) Magnaflow 5" mufflers and had the exhaust show weld them in.
Good clearance.
Old 03-03-2018, 07:49 AM
  #36
LaBLKv6Z's Avatar
*Just an update guys, last week of Dec 17 I spun piston rod bearing #3 while doing a burnout at the drag strip. Since then I've dropped the engine out of the car and completely disassembled the block. I parted out and sold pretty much the complete engine.
Old 03-03-2018, 08:08 AM
  #37
HCI2000SS's Avatar
Sorry to hear that man. I spun the #6 bearing and trashed mine 4 years ago so I know the feeling lol
Old 03-03-2018, 11:09 AM
  #38
LaBLKv6Z's Avatar
Yeah man, I was lucky I didn't make the pass and blow a hole through the block. Gives me a good reason to upgrade and install a tubular k-member.
Old 03-06-2018, 12:24 PM
  #39
LaBLKv6Z's Avatar
Spun a rod bearing in the burnout box.
Ran a 12.09 @ 120 on the previous run.
Back at home, beginning the tear down, took me about 2 weeks before I had the interest in tearing it apart.
Old 03-06-2018, 12:28 PM
  #40
LaBLKv6Z's Avatar
Dropped it from the bottom with a 1.5 ton jack.
Heads and rockers look great.
Old exhaust setup.
Oil leak from the cam sensor made a nasty mess.
Monster stage II clutch.
Quick Reply: Shark Gray 2000 SS build
