Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Swapping a 4th gen rear end
Old 04-15-2018, 07:05 PM
darren roar's Avatar
Default Swapping a 4th gen rear end
I have a 3rd gen that I swapped a 4th gen rear end in to. I have a set of c6 wheels I've put on it. My question is do you have to put longer wheel studs in the axles or get specific lug nuts for it?
Old 04-17-2018, 01:42 PM
SpeedingBolt's Avatar
You shouldn't need longer studs unless you are going to use spacers and the lugnuts are the same thread and seat design as what was used on the 3rd gen Camaro so you should be fine. Only issue you might have is the depth of the lugnut if it is a shallow capped design.
