Replacing shocks and springs
Old 07-20-2018, 05:23 PM
Jonarin's Avatar
Default Replacing shocks and springs
Hey all, this is my first post on ls1 tech!
I have a 98 z28 and the shocks and springs are shot. I want to go back to stock replacement and give the car and nice ride. I'm sick of going over bumps and hearing the rear end smack my bump stops! I heard the eibach slp springs give the car a 1inch drop, would you guys recommend it?
Please give me your opinions of shock and spring replacement!!!
Old 07-20-2018, 05:46 PM
HCI2000SS's Avatar
Are you sure the springs are shot?
Old 07-20-2018, 05:51 PM
Jonarin's Avatar
Yes. Car has 125k on it and it has the stock springs and shocks. Car appears and looks lowered but they are definitely shot.
Old 07-20-2018, 07:05 PM
HCI2000SS's Avatar
I think those SLP are like $300 bucks aren't they? If so I'd do what I did instead. I did the BMR springs for about $200 and then did a thicker spacer so I only dropped maybe 3/4" over stock. The Koni STR.T and Bilsteins shocks are a great replacement and value as well
Old 07-20-2018, 08:28 PM
Jonarin's Avatar
I found a used set with 15k on them for 150. What should I get for shocks? And should I buy strut mounts too?
Old 07-20-2018, 08:36 PM
HCI2000SS's Avatar
Cool. Yeah for $150 i'd give them a shot. Like I mentioned above the STR.T's and Bilstiens are a great affordable option. My strut mounts were fine when I switched so I just used them
Old 07-20-2018, 08:39 PM
Jonarin's Avatar
I’m going to scoop those and figure out what I want to do for shocks!
Old 07-20-2018, 08:46 PM
HCI2000SS's Avatar
Sounds like a plan
Old 07-22-2018, 09:27 AM
skopers3's Avatar
Koni orange is a great option that doesn't cost an arm and a leg.
Old 07-23-2018, 09:17 PM
Jonarin's Avatar
Do the konis work well with the slp option springs?
Old 07-24-2018, 02:55 PM
UMI Sales's Avatar
Sure, Koni STR.T can handle the SLP springs. We have them here at UMI (the Koni's).
Old 07-25-2018, 10:08 AM
Jonarin's Avatar
The springs I have are the 70009 optional slp springs. What do the run at umi?
Quick Reply: Replacing shocks and springs
