Engine swap
Hi Everyone. I’m new to this game and not a young guy at 60 but the excitement of horsepower and speed is still alive and well in me. I have owned this car for almost a year now after putting off my car ambitions for 40 years due to career and family and am having a ball with it. With a 454 and a 5 speed in it now I want opinions on ways to make it stronger and lighter. It all points to as LS upgrade from what I read. Question is which one? Thanks
I don't know a ton about it, but from going to car shows it seems like the most popular swap I see is the LS1 6.0.
Are you thinking about going with a turn key crate set up, or piece by piece?
https://www.ebay.com/itm/2015-Camaro...Y4EV:rk:1:pf:0
https://www.ebay.com/itm/2005-GTO-LS...LOcP:rk:8:pf:0
Or spend some Reggie Jackson type money and get this
https://www.ebay.com/itm/19260833-GM...0KMk:rk:1:pf:0
What kind of power do you want....or is it more just turn key and go.?
What are you plans for use, drag race, cutting corners, or just cruising ?
Is this a numbers matching car ?
Do you want to stay carbureted or go FI ?
Crate motor or "pull-out" ?
Factory controller or aftermarket ?
Doing your own work or paying someone ? (have they done swaps before/how many ?)
Just a few questions you need to ask yourself
200# could be had other ways IF you really wanted
MPG....I can't say its any better with a th350 and 4.10's
(BBC Vs. SBC Vs. SBE)
Edelbrock Performer RPM 454-O Oval Port Aluminum Cylinder Head350-60459
Edelbrock Complete Head Gasket Set for Big Block Chevy Mark IV350-73631$112.95
All totals about $2500-$2750 ?
LS swap...……$5000 to $10,000+...just depends on the deals you find.
Didn’t know about the big block vs ls trend going on.
Would I need to be concerned about using aluminum components bolted to the iron block or do the gaskets take care of the potential corrosion issues?
Doug, your ‘68 looks like a RUSH!
Need more pics of the Luguna , Kevin but the Rat and tranny sure makes my blood boil!
I did a bore and stroke, with ported heads and high lift cam on an LS3 for our gen 5 camaro. It's making just over 500 hp to the wheels. It's naturally aspirated and sounds really good. Had to go through some tuning headaches , but now its perfect.
It wasn't cheap. I think you could get what you want easily from sinking some money into your BB and it would be way less money than doing a full on LS swap.
Reasons I say the things I do is due to IF you go the LS path, I would really hate to see you having remorse if it didn't reach your goals in mind (and not really that cheap as most >me< found out). Big block torque is tough to beat
Steel/Alum. combos are not an issue...but I did forget to add that you "might" need new push rods also.... ALWAYS MEASURE PTV clearance !!!!
BTW, check out www.Camaros.net it's a 1st Gen site "mostly". I have the same user name over there
