Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Texas 2000 SS N/A Project
Old 04-03-2023 | 10:59 AM
  #261
Will_00SS's Avatar
The break-in tune is loaded and everything hooked up. I discovered one small coolant leak at the steam port fitting (possible o-ring issue, new fitting ordered) and a fuel leak at the rail. For the fuel leak, I'm altering one of my -8 wrenches as it is under the cowl and there isnt much room. Just needs a little bit more of a turn.
Also wrapping up the wiring installation of the gauges. Main one I need is the fuel pressure since I have a manual regulator now.
Once these items are completed we will be good to start.
Last item is brake lines. Found out if i go All flexline i will soften the brakes. Therefore, went to NAPA and got some hard brake line. Waiting on the fittings to go from 1/8-27 NPT to the bubble flare fitting.
For the front, having to figure out a way to go from a smaller fitting on the proportioning valve side to the larger bubble flare fitting for the MC2 port. Maybe I can use an adapter or something, not sure yet.
Hoping this weekend I can finally turn the key.
The following 2 users liked this post by Will_00SS:
blackbyrd (04-06-2023), brutalzo6 (04-04-2023)
Old 04-06-2023 | 10:35 AM
  #262
blackbyrd's Avatar
I had issues with the AN fittings on mine doing a y in the back of the rails.
My last iteration of it was getting away from that Y fitting and putting a T on the driver side rail, so one jumper from the T to the passenger rail. That way I could tighten that stuff up off engine and had a good shot at the lst fitting from my regulator to the T on the driver rail.
The following users liked this post:
Will_00SS (04-06-2023)
Old 04-06-2023 | 03:08 PM
  #263
Will_00SS's Avatar
That makes sense. With it in the car, I'd probably work to locate it in a different spot (maybe in future) but for now it seems ok. Definitely driven by the lack of space to work on the stuff under the cowl...makes one really consider the cowl delete
Old 04-06-2023 | 03:24 PM
  #264
blackbyrd's Avatar
Preaching to the quire on that one!
I got tired of fighting spark plugs and deleted my ac.......
Old 04-07-2023 | 10:33 AM
  #265
2ToeRacing's Avatar
Very nicely done. Waiting to hear the fire off. I think hard lines are a must with brakes and fuel lines.
Will_00SS (04-07-2023)
Old 04-07-2023 | 06:15 PM
  #266
01CamaroSSTx's Avatar
People will say that you never get back what you put into these cars.. I disagree because after all these years mine is still giving..
Soon it will be time to light the fires and reap its rewards..
Will_00SS (04-11-2023)
Old 04-17-2023 | 02:05 PM
  #267
Will_00SS's Avatar
Default Progress
Cranked over the engine but the battery needs replaced unfortunately. After sitting for a few years in the Texas heat not charging, it doesn't have enough juice. Last big thing is to bleed the clutch and slave cylinders. Fingers crossed.
Also worked on the rear brake lines and happy with how they came out. I'll post a picture tomorrow of how I ended up routing them.
brutalzo6 (04-17-2023)
Old 04-19-2023 | 10:45 AM
  #268
Will_00SS's Avatar
Default First Start Up
Last night I was finally able to turn the key and turn the car on. Run time is short since it was 12:30am and didn't want to **** off neighbors too bad, but couldn't go to bed without knowing
The following 4 users liked this post by Will_00SS:
01CamaroSSTx (04-19-2023), brutalzo6 (04-21-2023), jmilz28 (09-10-2023), Nathan C (04-25-2023)
Old 04-19-2023 | 08:34 PM
  #269
Sound bites like that leave you wanting to hear more of the music. That's one bad *** hot rod you have there.
Will_00SS (04-21-2023)
Old 04-21-2023 | 09:53 AM
  #270
Will_00SS's Avatar
Default Initial Shakedown
Got HP tuners hooked up. Car idled at 500 rpm for good while then ramped up to 3000 rpm without me touching throttle so trying to figure that out. Also working on adjusting the IAC counts, etc. but we will get there.
01CamaroSSTx (04-21-2023), brutalzo6 (04-21-2023)
Old 04-21-2023 | 10:04 AM
  #271
brutalzo6's Avatar
Congrats man! Looking forward to a longer video of it running.
Old 04-21-2023 | 10:43 AM
  #272
Will_00SS's Avatar
you and me both!
Old 04-21-2023 | 04:43 PM
  #273
440_Stroker's Avatar
That sounds damn near what mine does when I start it up. Congrats on her firing! And it fired immediately!
Old 04-24-2023 | 05:22 PM
  #274
Will_00SS's Avatar
Default Idling Break-In
01CamaroSSTx (04-24-2023), brutalzo6 (04-26-2023)
Old 04-25-2023 | 12:26 PM
  #275
Will_00SS's Avatar
Default Progress
Hadn't posted pictures of the rear brake lines yet. I used the stock bracket (shaved off the small tab on the side) to hold transition from hard to flex line. I mounted it to rear end with a self-tapping screw in the back bracing and made sure it cleared the panhard bars and fuel tank.
The stock heat shield has a tab that mounted to the stock upper panhard bar that had to be bent back for exhaust to clear. The BMR torque arm bracket had to be cut on the side, I needed to use the left set of holes. I'm curious if the bracket from UMI would mate up with the BMR torque arm. If this is the case, that would be the best combo as it would clear the 9" adapter from Trick Chassis without having to cut out anything. Food for thought.
I ran the connector and wiring for the wideband in the console and down through the transmission shifter hole. This worked out perfectly. Shifter and console are now back in place.
brutalzo6 (04-26-2023), Threadzy (08-21-2023)
Old 04-28-2023 | 11:15 AM
  #276
Codys89RS's Avatar
Wow!
This is done right! Makes me super excited to get rolling on mine now! Really hope my build thread is as documented as yours to help others as you have helped me with some ideas here.
Will_00SS (04-29-2023)
Old 08-19-2023 | 04:56 PM
  #277
raymond mckinney's Avatar
Nice build! N/A my style too
Will_00SS (08-21-2023)
Old 08-19-2023 | 06:54 PM
  #278
Spamfritter's Avatar
I've never understood this. I wouldn't own a car without AC in it.
Old 08-19-2023 | 07:58 PM
  #279
98CayenneT/A's Avatar
My a/c went straight in the dumpster.
Cleans the engine bay up nice.
And if it's hot enough that you need a/c then the tops come off. If it's to hot with the tops off then it's to hot to drive cause the car is dog **** slow in the heat anyways.
Old 08-19-2023 | 08:36 PM
  #280
Where I'm at, its almost always too hot to drive without air conditioning. Having the tops out and the windows down makes it feel like you are in a convection oven. Outside of the winter and a few days for what passes for spring, I wouldn't drive a car without AC. Hell, even then I run the AC in the wintertime more often than not. I dislike temperatures above 70F.
You are right though. It does clean up the engine bay nicely.
Quick Reply: Texas 2000 SS N/A Project
