SOM 2002 Z28 Camaro - build thread
#61
Ordered
OTC torque multiplier
2pod Autometer gauge cluster
Cinch clamps
Banjo clamps
After a few nights sleep, I came to the conclusion I could ruin someone’s day if the worm clamps slipped off at WOT on the drag strip. This weekend I’ll replace the 11/32 hose with 3/8ths and use cinch and banjo clamps instead.
Received the trans filter from Amazon, package pre-opened with generic filter inside. 5 out of the last 10 parts I’ve ordered from there have been opened with parts missing or wrong.
Cinch clamps
Banjo clamps
#63
Opening day weekend for test and tune starts in 21 days. I’m ganna use that weekend to dial in the suspension. I plan on index racing this year so should be a more exciting year for me.
Prepped the car some.
removed LCA’s, cleaned/greased, wd40, and tightened the rotofab.
hand sanded all the rotors (should of just taken to work and put them in the brake machine and saved time) lol
Rear tires rub both sides, need tiny spacers and longer studs.
The following users liked this post:
Threadzy (03-17-2024)
#64
Small progress this weekend.
After a bit of figuring; adjusted rear LCA’s so they no longer rub. Had to extend them about an inch. No need for lame spacers.
Next I worked on the battery tray. The plastic is split between the tray and the bottle. I was going to RTV it but found and ordered Dorman 603-116 from summit.
Next Drilled and tapped the bolt holes below the tray and installed a 3/8ths helicoil with copious amounts of red locktight. New 10.9 bolts.
Added wire loom to the 0ga ground wires to clean up the engine bay some more.
Ordered 3 bottles of hawks 600 dot 4 to add to the shelf. I’ll flush the motul 600 out at the end of the year and change to Hawks.
Ordered 30qts of pennzoil platinum ultra to stock up.
I’ll add photos later, they are not uploading.
Rabo73 (03-30-2024)
#67
Slow weekend, worked on friends Chevy OBS but got to poke at the SOM.
installed:
NGK TR6 plugs
DEI sleeves
Ordered:
trans filter
radiator cap
x2 3m urethane 08690
x2 Epoxy primer
To do this weekend:
install sail panel
swap trans filter
swap rear springs
putting off for later this year:
250amp alternator
harmonic balancer 10% UDP
o2 sensors
Flare up on 2-3 shift will need to be addressed at some point soon. Until then, Its time to drive this thing.
installed:
NGK TR6 plugs
DEI sleeves
Ordered:
trans filter
radiator cap
x2 Epoxy primer
To do this weekend:
install sail panel
swap trans filter
swap rear springs
250amp alternator
o2 sensors
Finkledbody (04-16-2024)
#69
Replaced Transmission filter - ran 8 bottles through, fluid came out black. Need to drive it then I’ll run another 8 bottles through it.
New radiator cap
New mini antenna
painted sail panel with epoxy primer. Going to wait for next weekend to install. That will give it plenty of time to cure.
New radiator cap
New mini antenna
Threadzy (04-30-2024)
The following 2 users liked this post by Finkledbody:
Rabo73 (05-05-2024), Treburkulosis (05-05-2024)
#71
I'm not criticizing your work, but does the sail panel stick out a bit at the bottom? Is that how it fits?
#72
if I were to do it again I would get an electric caulk gun. Just spend the money.
Finkledbody (05-06-2024)
#74
It does look good, and I give you credit for doing the work yourself.
#75
minor update.
Ordered:
3 qts power steering fluid
10 qts DexVI transmission fluid
x2 Chevrolet performance foam bump stops
Drove it 100 miles, time for more flushing
Ordered:
