metallic grinding noise 99 z28
99 camaro Z28 5.7 liter V8/Auto/12,000 original miles.Theres a metallic grinding noise coming from the left side of the engine. The metallic grinding sound stops when I either put on the A/C or defogger. So to recap I hear metallic grinding noise...and when I put the A/C or defogger on I then hear the clutch engage and the metallic grinding sound goes away. It immediately comes back on when I shut the A/c or defogger off. I noticed the belt tensioner on the top left of the engine shakes. I put more tension then less tension and the noise is still there. I dont believe its the belt but its possible.Maybe a pulley is loose or needs replacement. Maybe its the tensioner pulley. I dont have any idea. Any advice? Thank you so much in advance. Please reply to cobrakillr718@yahoo.com
well if it was the tensioner it would not come on when the ac comes on/off. The question is why does the noise start when the defogger is puty on. Does the defogger involve the ac?
sounds like a comressor clutch related problem. juat take it step by step, It does'nt sound like a tensioner. unless the ac being on forces extra tension on the pully?
I would look a the compressor.
