Where to get a Posi unit for my 1981 camaro
Ok everybody has told me to get a posi rear end because its a traction problem and i believe it , i was just hoping i could get by and be almost as fast with having the posi but i know its important to get the traction to get better times , now my question is does anybody honestly know where i could buy a posi unit for my 1981 camaro berlinetta and in this year they did not even offer a posi unit as an option to be put in , so where could i get one that is fairly cheap but a really good posi rear end, please someone theirs got to be a web site or someting because i really need one ? Thanks everybody Dennis
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
You could order an 81 Camaro with posi/limited slip from the factory.
First thing: what rear end do you have in the car?
10 bolt? if so, 7.5 or 8.5 ring gear? or 12 bolt?
Once you figure out what rear end you have, there are quite a few options for posi/limited slip/locked rear end choices. Eaton, Detroit Locker/TrueTrac, Auburn are a few choices.
I have a spool, so I couldn't recommend one, but check out websites for the information on each rear end unit.
Good luck!
Derek
Good luck!
Derek
Edit: I just read your other post. Engine swap. Was the car a V6 or V8 car to begin with? V6 may have had the 7.5" rear, V8 should have had the 8.5". Just letting ya know.
