Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
The official swap thread of my Camaro.56k ,RUN!
Old 11-21-2006, 11:45 AM
  #201
Posi12Bolt's Avatar
...an dennnn...
Old 11-21-2006, 12:32 PM
  #202
Deranged Rat Fink
badjuju342's Avatar
Got more pics to put up , I'll do them tommorrow.
Old 11-21-2006, 12:58 PM
  #203
Posi12Bolt's Avatar
I think this is one my most followed thread...
Old 11-22-2006, 06:24 PM
  #204
Deranged Rat Fink
badjuju342's Avatar
As promised , more pics. First off , if you looked a while back in this thread , you'd notice where I showed you that the BBK throttle body wasn't quite up to par in the polished dept. around the throttle blade . With a little help from Standard Abrasives , I took care of that. I started off with a medium grit roll on my die grinder to get this :
When you do this , you want to a smooth , sweeping motion , don't stop in one spot and "dig" , keep lightly going around the circumferenceuntil you have a smooth level surface.
After that step , I used the scotchbrite rolls in the kit until the surface was a very smooth , semi shiny , silk texture. This will flow well and not cause turbulence:
This techinique can be used on you stock unit , also. Just be sure to blow out any grit and wipe it down with good cleaning solvent like lacquer thinner afterwards. I then popped it on:
Old 11-22-2006, 06:38 PM
  #205
Deranged Rat Fink
badjuju342's Avatar
I also installed in the BMR strut tower brace. Sorry about the pic quality on this one , batteries were low. Here you go:
We now come to a part I was dreading : replacing the heater core . It wasn't as bad as I thought because the interior was partialy dissassembled anyway. Here's all the way stripped and heater core removed. This is one area you do NOT want to go cheap on . Buy a good quality one! I bought mine from NAPA.:
Got it in , but I let the dash off to remove some wiring and unneeded modules from the TBI setup. I then began to install the Coolflex heater hoses . I also have the matching upper and lower radiator hoses. They look really nice in person:
Had to stop there until the billet hose separators/hold downs arrive . I'll have more pics for you folks in a couple of days.
Old 11-22-2006, 08:42 PM
  #206
91RS's Avatar
I have a question, how do you go about wiring up the car for an LS1?
Old 11-22-2006, 08:47 PM
  #207
Deranged Rat Fink
badjuju342's Avatar
You'll use the stock harness/PCM that came with the LS1 but you'll need to convert it . Some guys will do it themselves or you can get someone like Speartech to do it for you. After the conversion , it's really simple. Painless Wiring also offers a premade wiring kit.
Old 11-22-2006, 08:52 PM
  #208
91RS's Avatar
If you convert the LS1 harness, why would you need the painless wiring too?
Old 11-22-2006, 09:24 PM
  #209
Deranged Rat Fink
badjuju342's Avatar
You wouldn't , it an either/or thing
Old 12-10-2006, 01:34 PM
  #210
MESS's Avatar
Very Very Nice
Old 12-13-2006, 07:51 AM
  #211
Genesis_26317's Avatar
So are you going to polish/paint the valve covers?
We are watching the rather long birth of the show car here.
Old 12-15-2006, 08:22 AM
  #212
Deranged Rat Fink
badjuju342's Avatar
I work a lot of hours so it's tough finding a ton of time to get it finished. I do need to do something about the valve covers , though.
Old 12-20-2006, 02:46 AM
  #213
black84z28's Avatar
awesome!...you know you'll be getting questions from me sometime soon!
Old 01-11-2007, 07:53 AM
  #214
Update! Update! Update!
I read every single page so far and I want more pics!
Old 01-11-2007, 11:17 AM
  #215
MESS's Avatar
I check this page every other day for updates...... it pulls you in!
Old 01-17-2007, 02:52 PM
  #216
LS1Formulation's Avatar
You should go through street and performance and have them chrome your valve covers and coil brackets. I have a set I may not use. I'll PM you about them.
Old 02-05-2007, 12:22 PM
  #217
Camaro396's Avatar
quite a bit of progress since I last checked in. Looks good.
Old 02-05-2007, 08:36 PM
  #218
SMKDFRD's Avatar
Talking
that is going to be one sick ride once it hits the street. you have to make a video of you playing around in it.
Old 02-07-2007, 01:44 PM
  #219
Deranged Rat Fink
badjuju342's Avatar
Well, got out today and decided to get busy in the garage.We're going to deal with the rear Baer brakes today.
First, removed the rear axles and installed the supplied baking plates for the calipers:
After making sure they were flush and the bolts were tight against the factory axle flange , reinstalled & reassembled the the rear axles. I snapped this quick pic because it is just good sense. You definitely want to put thread locker on the bolt that retains the pin that keeps the C-clips and axles in place. If that little bolt backs out ( especially at speed ) bad things are gonna happen! Note red on bolt:
Then , hung the rotors back on , and installed the calipers. Now we'll need to install the stainless lines and braided lines along with the parking brake cables.
Yeah , yeah , I know , y'all thought I had forgotten about this thread and you.
Old 02-07-2007, 02:42 PM
  #220
Yeah we did!
Paint those calipers!!!
Black ceramic coating or power coating will radiate more heat okay leave'em polished then.
Quick Reply: The official swap thread of my Camaro.56k ,RUN!
