- Camaro Common Problems<br>Important information to help you understand your Camaro.
Common 4th Gen problems??!!
I've had more wear and tear problems with the vette, ls1 f-bodies are remarkably durable considering the abuse they get put through generally. Or maybe I just bought a wednesday car as opposed to a monday or friday car.
Non-Abuse failures:
left turn signal
AC Compressor
Abuse related failures:
3 ring+pinon (10bolt lots of 5k nitrous launches)
1 posi unit (replaced with Eaton)
1 engine (lateral g cavitation, 6k in 2nd gear, very tight turn)
1 transmission (3-4 shift fork, synchros from lots of powershifting I would assume)
I don't keep track of what breaks now, it only gets driven hard or not at all, currently a headgasket, still using stock shortblock with newer crank and a couple newer pistons. Gonna drive this block into the ground over the next year. I don't drag race anymore, so the 10 bolt is fine for the corners.
I've never had to touch my window motors for some odd reason. Now that I've said that I bet they'll fail... lol
Right now, my passenger side DRL bulb is blown, my turn signals don't work. I'm going to change the bulb tomorrow when I change the oil and hope that it fixes everything.
And my sail panel speakers in my monsoon system blew out.
Passanger window motor
Posi unit
Whole rear end
Transmission
162 miles later Transmission Really who shatters a reaction shell?
Thats all that has been replaced because it broke
1. at less than 10,000 miles, the A4 solenoid was replaced by the dealership under warranty
2. at less than 10,000 miles, the rear window defogger button was replaced by the dealership under warranty
3. at around 48,000 miles, one of the turn signal bulbs was replaced
4. at around 49,000 miles, the bulb that lights up the A4 shifter console was replaced
1. 10 bolt
2. Battery
3. Passenger Signal bulb
4. 3-4 shift fork
5. Reverse Syncro
6. Passenger window motor
7. Clutch
8. Rear hatch lock
9. Front and Rear Rotors
10. Rear Shocks
11. Possibly new water pump
reverse syncro
passenger window motor
rear hatch lock
valve cover gaskets
and alternator (long story )
1. 10 bolt
2. Battery
4. 3-4 shift fork
5. Reverse Syncro
7. Clutch
8. Rear hatch lock
10. Rear Shocks
1.alternator 3 times in month in a half, bout once a year after that
- hatch latch didnt work under 50 degrees
-clutch was partly my fault, but replaced it about every 13k-15k miles
-bumpers started sagging
-hatch paint sucked
-the chicken wire or whatever you call it that holds bottom seat padding broke out so i was basically sitting on the floorboard
-evertime i released the seat belt fast it popped the window and scratched the tint(kinda my fault i guess)
-oh yeah, i dont know how many times i replaced the relay for the blinker
-replace door catch
thats all i can think of right now
both window motors
It's on its 3rd driveshaft
A/C clutch (never knew it existed before it broke)
I know there's more, but can't recall. Surprised I haven't had the signal problems yet.
Finally put a 12 bolt in
Waterpump at 60k miles also had a 99 SS and the waterpump failed within 25 miles of my TA
Multiple Front turn bulbs
Have a strange Driver side Rear light, Turn/Tail Light issue sometimes it works sometimes it doesnt
Received 1 ticket and 2 warnings. Still can't track down the issue
Reverse light always has condensation in it
both Belts
Multiple Pinion Seals
Axle bearings
3 clutches
Master and slave cylinder
O2 sensors are now bad and need to be replaced
Fuel pump
All speakers are blown
Door Moldings has the notorious crack in them
PCV location due to oil in the intake charge
Cam position sensor
Im sure there is more but I am getting more pissed off by the second just thinking about it
96K
Steering Rack 2x war. 35 and 35.5K the first was defective from Detriot.
Shocks 75k
Batt 20k
Drive Shaft recall war.
O2 sens war.& 95k
U joints 92k
water pump 96k just last weekend
F/R rotors 69k
muffler 2x 55k to a Magnaflow 91k to an Edelbrock
all bushings 88k
trans mount 55k
both window motors 2x war. 1x by me
knock sensor 73k, my fault washing the engine too much lets water collect it their pockets under the intake.
cruise is out now, but I left it on allot by accident
I had a 91 5.0 and had way more serious problems with it like 2 AOD tranny's in 2 years, a broken axel ,this car replaced the original car ford sold me a 90 5.0 that had been seriously crashed in testing at the factory in Dearborn repaired and sold to me as new.
hopfully A GM engineer see these post an addresses these issue in any new Camaro.
both Belts
Axle bearings
3 clutches
Fuel pump
Cam position sensor
Battery twice
I feel alot better after reading this post haha
Only problem i had with my z28 was both Cats died at 24,000 and some odd miles and set the SES light off, but they got replaced under warranty by the dealer and they also gave me a rental car for 2 days because they had to wait for the cat's. So i feel blessed so far considering how hard i drive the car.
This is my 2nd brand new Z28 my other one was a purchased brand new 96 Z28 m-6 convert and the only problem i ever had with that was it would go through alternators like crazy but atleast i got 7 years abd 140,000 hard driving miles out of it before i traded in on my 02 z28
1)-Replaced the Battery
2)-Replaced the Altenator
3)-Speakers
4)-Pinion Seal
5)-Passenger Side T-Top wouldn't seal.....Replaced it. No problems since.
6)-Rotors
7)-A4 Tranny due to the Vig.3200 Stall letting go.
8)-Drive Shaft twisted in half....Kinda My fault.
9)-MAF Sensor & O2 Sensors(Front) went bad.
However, I have replaced about 1/2 the car with Upgrades.....
You know,.....The way they should have come from GM in the first place.
After All......These are "Sports Cars".
The SS has 39k miles on it, and I Drag Race it every chance I get. (Only @ the Track)
