- Camaro Common Problems<br>Important information to help you understand your Camaro.
Common 4th Gen problems??!!
1. 10 bolt
2. Battery
3. Passenger Signal bulb
4. 3-4 shift fork
5. Reverse Syncro
6. Passenger window motor
7. Clutch
8. Rear hatch lock
9. Front and Rear Rotors
10. Rear Shocks
11. Possibly new water pump
2. Alternator ( I was attempting to drive my car on vacation....only got half way. Never had any problems with it until I decided to take it on vacation dammit. I can drive it to the drag strip, beat on it, and then drive it home but I can't cruise at 70 to the beach and back....I only went to MD from PA dammit...OH ya, and like a true car guy, my brother and I tore it apart in the hotel parking lot, got the alternator out and took it to a shop and had it rebuilt....got it back in and it lasted 5 minutes....
Man did I get screwed over
...Only thing that saved my *** was our family towing business
Most pist off I think I've ever been3. Battery ( because of the alternator)
4. Passener lower A arm ( bent when I got the car )
5. Tilt mechanism on the column ( no idea how that broke
6. Soon to be clutch....
All of this on a car that has 7k.....but it's such a sweet car
Rear pinon seal under warrentee
Transmission under warrentee (bad syncro)
A.I.R. pumps (2)
Water pump
Sway bar bushings (rear was squeaking badly)
Slave cylinder died in at a busy intersection prompting me to swear at my car the first time
Plastic clip that holds cruise control kill switch under dash broke scaring the h311 out of me when I pushed in the cluch to downshift on an offramp and the engine bounced off the rev limiter until I hit the brake. Second cursing and last cursing session about the car.
Despite what seems like a pretty good list, this is nothing compared the crap I went through with my 91' Z28 a the span of 25,000 miles. Compared to that, this car has been very reliable and dependable. The repair bills with the 91' made me seriously consider anything other than another Camaro.
1. Drivers side window motor
2. Front left turn signal bulb(water)
3. Turn signal switch (Dealer kept replaceing bulbs which didnt fix it)
4. Pinion seal leaking
5. wiped out rear bearings from shoddy pinion seal work.
Amazingly all was covered under warranty 7/75k (It has a loud muffler)
'Common 4th Gen problems??!!"
I added:
'Piston Slap'
So, I did not replace my piston slap, instead got it fixed.
...along with everyone elses listed 'Common 4th Gen problems'.
Not like when I used to hang out at places like www.sccoa.com for my t-bird, those things broke everything all the time it seemed, including mine. I haven't had any real problems with my Z since I got it 20,000 miles ago, for a total of 70k now. Well, slightly warped rotors, occasionally slow top...the motor seems real solid and never hear about anybody having motor problems besides a little oil consumption, even on the built ones. Not like on my ford, Soooo many things broke on that car, head gaskets, tranny, cooling system off the top of my head, though I did love the car and still have it in the yard actually. Someday maybe I'll fix all the little things it needs(not mentioned stuff, that's all fixed) and drive it again or sell it.
Don't really care about it since I have my LS1
that happened to me once?
i exited a ramp, pushed the clutch in and the revs just shot up to 6k
and bounced a few times befor i turned the car off completly............while still getting off ramp.
re-started, never happened again?
