1st Gen Camaro Pics
Originally Posted by Nine Ball
They didn't have a "nose up" stance when stock. That is caused by the leaf springs sagging with time. This is why you typically find owners putting inflatable air shocks in the rear of these cars. lol
Stock stance would actually have the rear of that car sitting higher than shown. It will show as much tire as the front wheel opening is.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Nice find, interesting color combo.
If you decide to do the HEI igintion, be aware they never came from the factory with them in '69, thus it can be a tight squeeze unless the firewall is massaged!
Derek
Derek
Derek
Derek
Super ride. If it's a true SS car it is rarer than the Z28 for 69. If it is and you want it original stock, get the SS hood with stacks and delete the Z stripes, IMO they're more happening than the Cowl hood everyone puts on these. (Not that your doesn't look good as it sits)
yea my dreamcar is a 69 camaro, im only 11 and i could give you any thing you want to know about that car.i want it!now!id put a 383 stroker in it. thats what is in mine right now.runs low 12s with street tires on it,bfg radial t/a,no drag radials!
Originally Posted by Elite_Hot_Rod
Thank you. For right now I'm going to leave it like it is except I'm going to put headers and an exhaust system on it then drive it. My original plans were to put a 572 crate motor, built TH-400 and a built 12 bolt in it and make it a bad *** street car and I may still do something like that eventually.
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
UBER-cool ride, and an "interesting" different color combo as well. If you have the scratch, those limited production alloy/injected 502 (or were they 454s?) ZL-1s are really sweet (are there ANY left??)!! It does not really matter, as long as we agree on NO POOPRA MOTORS/DRIVETRAINS!!!!!!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Rotflmao](https://ls1tech.com/forums/images/smilies2/rotflmao.gif)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
#32
#34
Originally Posted by Rickys S/C Z28
man great looking car!!! my wife and i are looking at a 67 right now hopw it works out!!! and not to hijack your thread but what kinda camaro can a man get in the 18k rang???
#35
Yeah I know. I'm going to see if I can find something that fits without having to massage the firewall. I think the Mallory unit will fit.
#36
Originally Posted by Z-Convert
The Mallory Unilite fits just fine. I have one on the 454 in my 67 Camaro.
#37
There's was a guy posting in the Texas section from Houston wanting to trade a 6 cylinder 69 camaro for a 98 and up F body car. He was asking 18K for it outright. https://ls1tech.com/forums/showthread.php?t=719283. Two weeks ago I helped a friend of mine go pick up a 68 camaro roller which is in pretty good shape, he paid $3,500.00 for it. The 67's and 68's are less expensive than the 69's are now. It all depends on what year your looking for and what condition you want it to be in. There are several good web sites which will give you a good idea of what's out there. Try this one http://www.cars-on-line.com/
nevermind i cant get photobucket to open the net over here in iraq suck ***!!!!
any way it a dark gray with blackstripesand an ss hood with raleys and 307 with a 2 speed glide need littel to no work to me the car id great and i got it for 18K
#39
Originally Posted by Hill23
nice looking ride man...
#40
Nice car, the first gen bug has bit!! You should upgrade the rear suspension. You can go all out with a four link system that will make it a corner carver. Detroit speed and Heidt's both have bolt in four link systems. This allows you to run coilover's in the back. You will get some drop with the four links, but you can dial it in so as to control how much drop. They are bolt in systems and require no cutting, which on any original 69 these days is always a good thing. The systems also allow for use of a 9 inch rear, which you will likely need if you are dropping in a 572. In fact, both systems allow you to order a 9 inch housing already to bolt up to the new four link. Chris alston also makes a four link bolt in system, although I don't know of anyone that has used it as it is relatively new. I believe it is the same system that is used with air-ride rear suspension, although alston has the set up for coilovers as well. Also, look to upgrade your front as well. I just put on some BMR UCA's and LCA's with QA1 coilover's for my 68. It makes a world of difference in handling. The other benefit is that you can dial in ride height with the coilovers. Good luck, looks beautiful.
Chris.
Chris.
