Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
My new 98 Z28 (Under the knife)!
Old 03-25-2010, 08:22 AM
  #181
JRracing's Avatar
LOL I got a few guys interested in my SS. But I am holding fiem on the price as I don't need to sell it.
My car should up and running by next month..
Old 03-25-2010, 06:27 PM
  #182
LT1Formula007's Avatar
Hell yeah man! Hope everything goes as planned bro.
All I need now is:
The Fuel Pump (walbro 255) and wiring harness setup
Battery relocation kit with the cut-off switch
Go get the MWC Fab 9 and install it along with the Strange rear Brakes
An Anti Roll Bar
Strange CM Driveshaft
A Tune
All my gaskets and fluids
new o2 sensors
an allignment
and some other small things.
So I'm saying by July 1st I'll be ready to Play!
*Just in time for Summer!
Old 03-25-2010, 07:14 PM
  #183
MOD MARKER!!!
Ok here is what the car has on it, or going back in it as of RIGHT NOW!
Just trying to update this thread a little since the car has had so many changes over the past couple of years!
Engine:
LS2 403 CID Stroker
Cam- 248/254 .615"/.623" 110 LSA
Heads- Stock LS6 Heads with PRC Dual Springs (.650" Max Lift)
K Tech Forged 4.00" Stroke Crank
Forged Diamond -2cc Flat Top Pistons
Callies Compstar Rods with ARP Bolts
SLP Oil Pump
LS7 Lifters
LS2 Chain
11.5:1 Compression
LS6 Valley Cover
FAST 92 mm Intake and PTM 92mm Throttle Body
ASP 25% Underdrive Pulley & OD Alternator Pulley
SLP Air Lid and K&N Air Filter
TCI Flexplate SFI Approved
Transmission:
Level 4 Built 4L60E Transmission
Yank SS4000 Stall
Derale Deep Transmission Pan
A BIG Transmission Cooler
Driveshaft:
Was a Stock Aluminum LS1 D/S
Upgrading to the Strange Chromemoly D/S when the MWC Fab 9 goes in (Next Month)
Rearend:
Was a Stock 10 bolt rearend out of a 6 speed Trans Am. Has 3.42's and a Summit Differential Stud Girdle Cover on the rear!
Putting in the MWC Fab 9 in next month! (Fab 9 is on order)
* 3.70 Richmond Gears, Detroit Locker Diff., 35 Spline Strange Axles, Back Brace, Powder Coated Black, and Aluminum Center Section!
Brakes:
Front Brakes are Stock Replacement (Pads/Rotors/Calipers)
Rear are the Strange Race Brakes Kit (pads,rotors,calipers,etc)
SJM Line Lock Kit and ABS Delete Kit
Still Gotta put in a Prop. Valve for the rear brakes.
Suspension:
UMI Tubular K-Member
UMI Subframe Connectors (Bolt In)
Dbl. Adj. LCA's (Spherical QA1 Rod Ends)
Dbl. Adj. PHB (Spherical QA1 Rod Ends)
QA1 Rear 12 way Adjustable Rear Shocks
Stock Springs (All 4 corners)
Stock A-Arms and Struts in the front
MWC CM Chassis Mounted Tq. Arm assembly with DS Safety Loop
Fuel:
Nasty Performance Billet Fuel Rails
Delphi/Lucas 42# p/h Fuel Injectors
Walbro 255 LPH Fuel Pump and Booster Harness (Dual Walbro's Later on)
Weight Delete Mods:
A/C Portion of the HVAC was deleted
(Everything that had to do with the AC is gone!)
Passenger Air Bag Assm. w/Bracket
Rear Seats
Rear Seat belts
Front Sway Bar and Brackets
Washer Resv. and Bracket
Front Crash Support
Valance between the radiator and condensor (behind Washer Resv.)
Took out the Factory carpet and replaced it with Lightweight carpet
Stock K-Member (went to UMI Tubular K-Member) -25#'s
Emissions Crap
ABS Delete Kit
*I'm Moving the Battery to the rear to get the extra weight off the front! But this will add a few pounds with all the wire and etc that has to go back into the car!
Wheels:
I have a set of Prostars for the Track...
15 x 10 for the rear with 27 x 10.5 x 15 MT ET Streets
15 x 4.5 for the front with some cheap street tires (haven't bought these yet!) But they are next on the list after it's running!
For the Street I have a set of Black Z06 Style Rims with Rivets
17 x 9.5" Fronts, and 18 x 10.5" Rears
Interior:
Pretty Much just 1 Stock drivers seat when I go to the track.
Other than that I just have the 2 front seats in the car when I'm cruising on the street!
All of the panels, console, dash, and etc are still in the car!
Exterior:
Pearl White
Black Vinyl Hockey Stick Stripes
Blacked out Taillights, side markers, and Turn Signal lenses
Gloss Black Berger Panel
"Harwood" Fiberglass- (Raised & Widened) SS Hood
EBAY SS Rear Wing
Billet Grille!
Exhaust:
TSP 1 7/8" Longtube Headers
TSP ORY Pipe
SLP Loudmouth 1 Catback
Future Mods:
-Wolfe 6 point bolt-in Roll-Bar for now(10 point CM cage this winter!)
-Possibly a Nitrous Kit towards the end of this racing season
(Who Knows what else I will throw in this thing lol!)
-Looking at a FAST 102/102 setup here in the near future as well!
-Planning on going to Strange DA Front Struts and 300# Springs
-And UMI Upper and Lower A-Arms
Goal for 2010:
I would like to run a 10.50 N/A at "around" 130 mph
Put a 100 shot wet kit on it and run a 9.99 or better at 135 mph or so!
Old 03-25-2010, 08:22 PM
  #184
VF1Skullangel's Avatar
I like the RS better.
Old 03-27-2010, 09:11 PM
  #185
LMAO... Thanks for raining on my parade lol.
BTW My fiance' says "Thats right". hahaha
She wouldn't let me put the 403 in the RS unless it becomes "her car".
I'm not ready to part with my motor just yet.
I told her to let me build a 427 or a procharged stroker and I would.
Thanks tho man! I like the RS too!
Old 03-28-2010, 11:24 PM
  #186
JRracing's Avatar
That's a hell of a list.
I don't see why it would not go 10.50's at all. It could do even better than that. Take out everything you don't need..
I would also look into having my guy port those heads. That along with a fast 102mm I think would pick up a ton. That is a lot of CI and cam for a set of stock ls6 heads. But I would keep them if I were you and get them "worked". It would add to a stockish look from the naked eye. I mean you not seeing "AFR" or "Trickflow" on the end of them. Most people would think it is a stock bottom end with some ls6 heads and a cam/intake kinda car LOL.
Old 03-28-2010, 11:39 PM
  #187
TRUE! I think if I was to pull the heads off tho, I'd HAVE TO put a set of TFS 235's on man! They would definentaly flow more than some worked over LS6's and I'd just throw a head plate over the end of the head on the passenger side and the p/s pump would cover the Drivers side I believe.
I really want to do a 427 build tho! I'm pretty sure my next build IS going to be a NA 427, or a Procharged Stroker of some sort!
Them are my ONLY 2 choices left to make with the car now lol!
I decided to go with a MWC 8 point roll bar in the next few months also! I'm gonna talk to him when I go get my MWC Fab-9 and see what he thinks as far as a waiting period and a price will be. If he could have it done in a couple weeks or less, I'll have him do it. If not, I'll just order a Bolt-In 6 point Wolfe Racecraft Roll Bar and use that til this winter. Then let him do it.
Old 03-28-2010, 11:53 PM
  #188
WINTER PLANS are....
Midwest Chassis 9 Inch with 3.70 Gears and a Detroit Locker Diff. 35 Spline axles, Tq. Arm, DS Loop, (Back Braced) etc...
10 point ChromeMoly Cage
Ported FAST 92mm Intake
TSP 1 7/8" Long Tube Headers
Dual Walbro's 255 lph Fuel Pump setup
UMI Tubular Front Suspension Setup with QA1 Coilovers and 275 lb. Springs
Weight Reduction
Pro-Stars (15 x 4 and 15 x 10) Wrapped in 27 x 10.5 x 15 MT ET Streets on the rear and some street tires for the fronts.
AND A RETUNE....
*Hoping my work will stay busy so I can have it out by MID summer.
Originally Posted by JRracing
That is a big a$$ list of mods in a short amount of time. I hope your work is busy. LOL.
Remember that Quote from you last year man.
Well I almost got everything. haha
But your right, I had to stay busy. And it sucked b/c I didn't start making any money til After January hit! But now I'm well on my way to marking each item off on my "original" Winter Mod List!
Old 03-30-2010, 11:34 PM
  #189
Well I got a little spare time to play with the car today. I didn't get home til late, SO I decided to just work on the car! I finally got the transmission back in the car along with the TSP 1 7/8" LT's... Which I must say are VERY Nicely Built. The LT's Fit AWESOME... Thank You TSP!
Here is some pics...
I got the car jacked WAYYY Up in the air to be able to slide the Trans under it with it on the tranny jack...
Here is the SS4000 Stall (Fresh from YANK last Tuesday.)
Got it strapped down to the tranny jack to keep it from falling on me since I'm the only 1 putting it back in the car....
Here is a pic of the inside of the TSP 1 7/8" LT's (VERY NICE)
Finally got the Transmission bolted up!
Here is the engine bay as of today...
And I just took this pic to show how much room I have to get behind the engine if I need to. For what reason, IDK.... But oh well! It's really open there w/o the AC and Emissions BS there.
Old 03-31-2010, 12:16 AM
  #190
JRracing's Avatar
Right on man. Keep at it!
Old 04-04-2010, 08:00 PM
  #191
DID some more work on The Camaro Today!
I need to have this car running in 2 weeks. Long story short, I have someone who is VERY interested in buying it without the 9 inch, and he said He is just waiting to be able to drive it and we can go from there. I quoted him a price, that he is obviouslly considering!
So I guess we'll know something in a short while!
I'm kinda happy about it, b/c I already have some plans for my next build, and At the price I'm selling it for.... I'll be able to build 1 NA$TY a$$ Ride. haha
Wish me luck guys!
Here is some pictures of what I did to the car today, Not alot but at least I worked on it. lol
First thing I did was pull the Map sensor out of the FAST Intake, Tap the hole to a 1/2-18 thread pitch, and put a few fittings in there to prevent the oil leak and vacuum leak I had last year from reoccuring this year.
Come to find out, That my seal for the MAP Sensor was messed up and was leaking and allowing a vacuum leak b/c it was not flush inside the intake! I was wondering where the oil leak was, Guess i found it huh!
Also put the wiring harness back in today! That was something I've been wanting to get done soon, so I fiured I might as well do that today!
Old 04-04-2010, 09:04 PM
  #192
CHRRRIS's Avatar
Just curious why you're gonna sell it after putting all this time and work into it? It sounds like it will be a blast to drive.
Old 04-04-2010, 10:28 PM
  #193
Well, to be honest with you, I don't really want to sell it b/c of how much time, money, and fun I have in this thing! BUT, I can pretty much get ALL of my money back out of the car. And to me, it's worth it to sell it and go the route That I have been wanting to go for so long. Like I said though, It's not for sure. But there is a Pretty Strong chance it will sell!
If so, I'm going to buy a Nice Trans Am WS6 or Formula Maybe a Formula WS6 if I can find 1. And then build it up. Since I'm keeping the MWC Fab 9, I'll already have a rearend. And then I'll just buy a Coan TH400 setup with a 4000 Stall and buy a NA Pump Gas 427CID LS2 Dry Sleeved Engine From ERL with TFS 235's, A FAST 102/102 Setup, and a decent size cam. And then slowly add all of the suspension to the car while I'm building it! With that said, I'll be on the hunt for 9's my next time around!
I have learned something along the way. With building this car I found out where to spend the money and where to NOT spend the extra $.
So I am confident in building a VERY stout Street/Strip car my next time around with the Budget I have in mind!
Just hoping he buys it now! lol
Old 04-06-2010, 11:15 PM
  #194
Finished up with the accessories and Battery Cables today. And the wiring harness is finally all hooked up now!
Planning on finishing up the Transmission stuff (Driveshaft, Tq. Arm, Shifter Cable, Trans. Cooler, Lines, etc.), Starter, P/S Pump Pulley, Put the other Valve Covers back on, Install new plugs, Coils, Plug Wires, Put the PCM Back In, And anything else that I can get done tomorrow!
Although that's a big list to accomplish in 1 day, so we'll see what happens!
Then, I'm gonna try to put on the Exhaust Friday Afternoon.
Might be able to start it.
So much to do, So little time!
It seems like I'm never gonna finish it, but I'm getting closer all the time! haha
Here is the pics of today's progress!
Old 04-12-2010, 12:53 AM
  #195
OK! So I Finished up the Z!
Whoo Hooo
Heres the latest pics...
Old 04-12-2010, 01:05 AM
  #196
Here is the new video of it idling!
I'm excited to hear it finally start again after 6 months.
View Video on FQuick
Old 04-12-2010, 01:29 AM
  #197
CHRRRIS's Avatar
Sounds mean! How's she drive?
Old 04-12-2010, 07:52 AM
  #198
OMG, It drives sweet man!
It HATES Street Tires though hahaha
I really don't wanna sell it now. lol
But, I can always build another 1 later.
*Hell that's half the fun!
Old 04-12-2010, 08:49 AM
  #199
Chadlee2KZ's Avatar
Glad to see it running again!
Old 04-12-2010, 01:58 PM
  #200
Thanks Man...
Quick Reply: My new 98 Z28 (Under the knife)!
