Syclone LQ4/4L80E tc78 build
Some background first. I purchased syclone 1060 back in March of this year. When i first got the trck i really wanted to do a 6 speed swap because i really like 6 speeds. I soon realized that i wanted to make the truck really fast in a staight line and a 6 speed is not going to do that. Then i wanted to do vortec heads and a big turbo but didnt want to drop $2500 on a build 700r4. So i said i would do a 4L80E. Until i did some research and realized how big of a rip off it is to do that swap.
Now to the present. My goal at the end has always been to run i the 10's. I didnt care how i got there, but i wanted to keep it streetable for daily use. So having LS powered cars before i decided that that was the best choice for speed and reliability. After alot of research i made a game plan.
-LQ4/4L80E
-tc78 turbnetics turbo
-60lb injectors
-front mount intercooler
-2bar speed density tune
-arp rod bolts
-custom made headers by me
-modified stock oil pan by me
-motor/trans mounts by me
-3600 stall converter
-custom build wiring harness by me
I will be keeping a complete log of every dime i spend. I am going to prove that you make a syty reliable and super fast without dropping 15k. I will be doing everything myself except for the tune. I will make everything that i can and buy only what i have too. There is alot to buy so i will list it as i get it. right now i am shooting for 550whp. I will see how far that gets me at the track and go from there.
Here are some rules i am going to stick to. Keep A/C. Keep AWD. Do this as cheap as possible but do not compromise on safety. Run in the 10's and drive home on pump gas.
Here is the truck
And now to start the build thread.
Got to stop all that power so i got C5 brakes all around. $275
And got this. 01 LQ4 and 04 4L80E. $1610
build total $1885
__________________
-LQ4/4L80E
-60lb injectors
-arp rod bolts
Here is the truck
build total $1885
__________________
i started collecting parts on 11/08/08. just 3 days ago. had the surgery yesterday. i work full time and go to school so i dont know how long the swap will take. a huge thanks to ls1_chevelle for all the inspiration. he has one bad *** car, alot of my build will be like his.
-LQ4/4L80E
-60lb injectors
-arp rod bolts
Here is the truck
build total $1885
__________________
-LQ4/4L80E
-60lb injectors
-arp rod bolts
Here is the truck
build total $1885
__________________
Is there a big length difference in the 4l80 and the factory 700r4?
just waiting on some oil line fittings
ready to pull the motor/trans this weekend?
broke my wrist in march. i went over the bars on my mountain bike and landed on my arm. i was on the smallest jump ever.
worked on the pan some more
Very cool! I have been wanting to do a Gen III/IV swap into a SY/TY and keep AWD.
How are you going about keeping the AWD? I'm going to ask some dumb questions cause I'm not looking at a TY now. Are you going to use the T-case that was in the truck or is the 4L80E have one that came with it? or is it built into the trans?
Also what all does it take for that Vett brake swap, is it just a bolt on with a different bracket? If so where do you get that? I'm trying to remember are those truck rear disc and do you have the vett setup out back too?
to keep the awd i have to put a huge notch in the oilpan and spend a ton of money to mate the stock sy t-case to the 4l80e. $450 for a new 32 spline t-case input, $130 for a new shifter cable and bracket, and $200 for the adapter for the t-case to bolt to the trans.
for the brakes you can buy bolton brackets. im going to make my own though.
