turbo guys. these the perfect up and forward headers?
Old 09-05-2009, 01:10 AM
71 chevy's Avatar
Default turbo guys. these the perfect up and forward headers?
so it was pretty much the ls3 c6 headers but I stumbled across these on ebay and they look like for a couple of hundred more than the cast manifolds they almost work as well as custom made forward and upward facing headers.
anyone know anything good or bad about OBX, or these headers in particular?
it would be really nice if they would work with the coils in the stock location
also, what type of flange is that on the end? I browsed summit racing and could not find a suitable reducer.
Old 09-05-2009, 01:48 AM
camaropilot's Avatar
Well from what I hear they crack but if you have a tig and are good with stainless go for it
Old 09-05-2009, 09:36 AM
TJ
TJ's Avatar
ive also seen them crack. they are just made from thin material.
you dont want to hang your turbos right off them. make sure they are braced well.
hard to beat them for the price.
Old 09-05-2009, 05:16 PM
71 chevy's Avatar
dammit. I hate that they could possibly crack. they look well made. I guess Im more concerned with being able to use the stock coil location and wires.
do you think they'll work for that?
Old 09-05-2009, 05:32 PM
NemeSS's Avatar
easier to mix and match stock manifolds. if your car has a large steering gear box, the truck forward facing manifold may hit. i have found that using a 98-99 pass fbody used on driver side facing forward clears the larger steering gear boxes. and tucks in closer to the engine. although eliminates the use of
ls1 fbody alt configuration.
Old 09-05-2009, 05:37 PM
71 chevy's Avatar
ok, I found that they are an almost exact replica of these pontiac jba headers.
any one have experience with these?
http://www.jbaheaders.com/feature_pages/04GTOnew.asp
nemesis, Im pointing them upward so I dont think I have to worry about hitting - or do I?
its a nova
Old 09-05-2009, 06:38 PM
NemeSS's Avatar
looks like they may not hit car, but will prolly be to close to valve covers.
the first pic, what are the headers for? gto?
Old 09-05-2009, 07:42 PM
Sandmann120's Avatar
Those header could work nice, just do away with the flange, and weld on a vband. Build from there. I'm curious how they would work on an S10.
NemeSS, you raise a good point...They could be pretty close to the valve covers. Any pics of using the '98 Fbody manifolds on the DS? Im looking for something to fit an up-coming S10 build. Not worried about Alt mount. Thats easy enough to address later on.
Old 09-05-2009, 08:17 PM
71 chevy's Avatar
The first pic, what are the headers for? Gto?
gto..
Quick Reply: turbo guys. these the perfect up and forward headers?
