quick question msd 6010
if i buy the msd 6010 from a summit or jegs.. will it come with the harness too?.. or will i need to shell out another 85-100 bucks.. thanks.. it already cost about $300 is that just for he box ,or box and harness,,thanks.
Location: Your girl's back door giving her the long stroke while you're at work
it comes with a harness that hooks up to the MAP sensor, Crank sensor, Cam position sensor, Left and Right Coil packs. Also has a hook up for a two step
The other harness (PN 88something) is so you can hook it up to the factory wiring harness. The one with the 6010 is long enough to where you can mount the box on the front of the intake and run the wires under and though the back of it(like mine is)
well i got it today,, real easy to hook up,, . but my laptop doenst have a serial port.and its vista... . only usb,, now gota order a usb convertor... what apain in the a#$.... owell.. other parts wont be here till lator on next week anyways.. so no rush for now...
and yes i tried down loading the newer version 3. something,, didnt want to load up.. and i dont want to get rid of vista, sounds too complicating for me..
you can get the serial to USB converters for $9 on amazon. I got a cheap one and it works fine. it took a few tries to get the port numbers working right, but once that is done everything is very simple to use. Don't get discouraged, it is worth it when it works.
MSD needs to update the boxes to be USB. Adding a card reader so we can data log would be another bonus that shouldn't cost too much.
If your crank position sensor is on the top/rear of the engine (black in color) it is 24 tooth...listed as '97-'05.
If your crank position sensor is on the timing cover (gray in color)...then it is 58 tooth reluctor...should be '06 and later.
im not sure if i answered ur question..
FYI: MSD preset the rev limiter at 5500 rpm so if you pull past that you'll have to change it first thing, guess how I know
