replacing LT1 rag joint shaft with LS1 shaft
Old 10-24-2009, 01:00 PM
demonpixel's Avatar
Default replacing LT1 rag joint shaft with LS1 shaft
Apparently it's more beneficial to replace the LT1 Fbody intermediate steering shaft with an LS1. I just have a quick question, does the bulky part of the LS1 shaft go toward the rack side, or toward the firewall side?
TIA!
Old 10-24-2009, 08:33 PM
TheBiz's Avatar
Towards the Rack.
Old 10-24-2009, 11:18 PM
demonpixel's Avatar
Awesome, thanks Biz, I got it in there.
Old 10-25-2009, 03:04 AM
DGGM WX3's Avatar
are the shafts completely interchangeable with each other? I thought I heard somewhere they weren't?
Old 11-11-2009, 06:27 PM
TheBiz's Avatar
No. LS1 knuckle and rack go together. LT1 knuckle and rack go together.
Old 11-25-2009, 09:59 PM
SixSpeedDeath's Avatar
So do the rack and intermediate shaft bolt to the column, subframe and tierod ends without modification?
Old 11-26-2009, 08:39 PM
TheBiz's Avatar
I used an LS1 tubular K member in my conversion, so I'm not sure about the LS1 rack working with the LT1 K. The column does work however.
Old 11-27-2009, 08:04 PM
That's cool, i called Spohn Racing and they said it was the same mounting position from LT1 to LS1 K-member, the only difference in the K-members is aparently the motor mount positions. Now for my final question, Will the same power steering fittings fit from LT1 to LS1?
Old 11-28-2009, 07:04 AM
TheBiz's Avatar
Should. Once the rack and the pump are on the car, the hoses will match up.
Old 11-30-2009, 07:23 PM
So to make this simpler, it's easier to explain what I'm doing. I own a 1996 3.8 Camaro w/ 5 speed, I also purchased an LS6 w/T-56 trans out of an 04 Cadillac CTS-V with all the goodies. The Rag joint is making driving interesting and I don't have the cash yet for the swap, so I'm trying to upgrade and prepare for the swap, (why fix this twice? ) So I have the 3.8's Power steering pump, and the old school rack. Although thepump isn't the same 3800 to LS6 i was hoping the existing power steering lines would work with my LT1 style rack, or did you have to swap a pump and lines into your vehicle to make it work? I'm buying the rack and intermediate shaft for the LS6 swap regardless, I just don't want to have to shovel out $250 my cost for the rag joint style intermediate shaft as well. Any ideas?
Old 12-03-2009, 04:34 PM
TheBiz's Avatar
Honestly, I'd just swap everything to the LSx style. I went a head and did it. Just find a parts car somewhere and buy everything from the same car. I found a 'bird that had been smashed in the rear end. I got the pump, lines, rack, and steering knuckle for $150.
Old 01-08-2010, 07:48 PM
Just updating. The rack is in with intermed shaft. got it paid for and shipped, rack and intermed shaft, for $113. It Drives A LOT better. Thanks for all the help.
Quick Reply: replacing LT1 rag joint shaft with LS1 shaft
