Engine start up with out ignition wiring
Items you need to run any engine.. Air, Fuel and Electircal. for any period of time (short or long).. so .. not sure how you would run with out the ING wire connected from the coil to the plugs or to tbe PCM/Distributor.. ?? Let alone the connections to the injectors, coils and sensors (some can be left disconnected).
If you are trying to check the health of the engine without running it.. I would suggest you try a Leak Down tester or compression tester to start wtih. Pop the oil pan, valve cover and the lifter valley cover off to inspect the engines internal. Thats about all you can really do without starting it up.
