66 Chevelle, Can I use my stock throttle pedal torque arm??
I am wondering if I have room to do like pictures of TomM's 66 nova. Anyone do something similar? If so what throttle cable's did you buy?
Thanks!
Thanks!
Looks like it will work, at best you may have to remove the arm, and enlarge the hole to fit the carb bushing, if you decide to go that way. If not, you can adapt the ball stud to what you have. So unless your block is right up against the firewall, you should be fine, You can always add a bracket to the existing arm to give you more reach......
T,
T,
