91 GTA Clone with 5.3 T56
Old 11-03-2010, 08:30 AM
91FormulaKiller's Avatar
Default 91 GTA Clone with 5.3 T56
So i pulled the trigger on a 5.3 T56 swap into my 91 Formula /GTA Clone a month ago and im about to buy the engine this Friday (5.3 L33) I chose the L33 over the LM7 for the obvious bump in power, wieght savings and heads. I just wanted to hear some suggestions from you on what sort of starter performance parts you would put into this? I'm looking for a mild 325-340 rwhp since its a semi-daily driver 9 months out of the year. Again, mild performance. I already have an idea of what to put into it but i thought some other members might have some gains i can get out of this engine that i havent thought of. Thanks!
Old 11-03-2010, 08:40 AM
Isolde's Avatar
Start by deciding on turbocharging or ordering the StainlessWorks headers from Hawks Third Gen Parts. If you go that route, you only need 1.75" primaries.
Old 11-03-2010, 10:13 AM
I have seen videos of 5.3's w/turbos and they are quite impressive, however i think i may stay away from boost for this swap as i dont really need it for what the car is being used for. The SW headers are on sale actually right now but for budget reasons im using stock F-body manifolds for now, i will upgrade to them in the future, i do my own fab work so i dont mind re-fab'n the exhaust a 2nd time.
Old 11-03-2010, 02:34 PM
Pocket's Avatar
Stock 5.3 longblock, LS6 cam, LS6 intake, stock T56
Should be a fun little ride making nearly the same power as a mild cammed LS1/T56
Old 11-03-2010, 04:12 PM
Thats what kind of combo im coming down to Pocket (you know me as 88FormulaKiller on TGO). LS6 cam swap requires matching springs correct? I do like the TR220ish cams as well. Read that over 230 is tricky to tune though.
Old 11-03-2010, 06:48 PM
Pocket's Avatar
Yes, match your springs to the cam lift. Stock springs are rated for the stock cam and barely that. The LS6 cam is a decent bump over the stocker and the old springs will bind. Luckily LS6 yellow springs are very cheap and common
About 230 @.050" is generally accepted to be as big as you want to cam a 5.3. Of course, most of the threads about it are polluted with overcammed engines that the owners say runs fine
Old 11-06-2010, 10:14 AM
dynodanmanda79's Avatar
I'm running an LM7/T-56 and it's a pretty good setup, definitely better than the 305 tbi/t-5 setup the car came with. You just can't beat the LSx platform, there is more power to be made and better mpg's in the end. I love my setup and it always opens up the door to a 6.0 later on down the road... which I do plan on doing someday. The L33 should be a nice engine to work with and make plenty of power, good luck with your swap.
Old 11-06-2010, 10:30 AM
thanks dan, im sure i'll be buggin you alot soon! lol
Old 11-06-2010, 12:45 PM
Not a problem man, that's what we're here for!
