Jeep YJ 5.3L swap (completed)
Old 04-11-2012, 08:21 PM
  #161
Docked Wage's Avatar
Originally Posted by White Lightning
when you installed the 8.8 did you install the rear trac bar?
Sorry I missed this. Yes, I did install the MORE traction bar. It made a big difference in how the Jeep launches.
Take a look at post #126 for the pics of the install.
Ken
Old 04-13-2012, 08:55 PM
  #162
White Lightning's Avatar
MY 231 c has 5 on one end and 6 on other end . its stamped zr2 . i got it from a tranny shop,. the stock one that came with my tranny was 6 and 6 and woulnt bolt to the 231c front half
Old 05-15-2012, 09:08 AM
  #163
ballistx's Avatar
Default cruise control
Has anyone with a 5.3/5.7 swap installed cruise control?
Old 05-15-2012, 10:17 AM
  #164
It's very possible on a DBW setup. There are a few wires (4 or 5) which come out of the TAC Module 16 pin connector that would go to switches on the dash or multifunction switch.
Do a search and you should be able to find what you need to do.
Ken
Old 05-16-2012, 04:34 AM
  #165
ZTwentyAteU's Avatar
cool build! I have a 5.3 yj as well. I still need to do an 8.8 swap myself. I'm running a 241c transfer case.
Old 01-12-2013, 08:46 PM
  #166
Carolinanomads's Avatar
Because you did such a good write up of your swap, I got the courage to take the knife to a 2006 Jeep LJ with only 58,566 miles on it.
I bought a wrecked 2003 Suburban, parted it out and got most of my money back. I sold the Jeep 4.0 parts and got some more back. I plan on doing a complete write up like you did to be able to help others including a break down of what I spent.
I have driven about 2000 miles now and am very pleased with the performance of the Jeep. I get 15 to 18 MPG but need a tune and plan on getting one soon. My tuner is sure he can get me 20 MPG and still burn all the rubber I want!
I posted a few pictures on my Face Book account of the swap, will do more later on a build thread. Link to pictures: https://www.facebook.com/media/set/?...3486920&type=3
Old 01-13-2013, 06:48 PM
  #167
Thanks for the compliment.
Welcome to the 5.3 Club. This swap was by far the best performance add I've done to any vehicle in my 25 years of being a gearhead. Dollar for dollar it cant be beat.
Enjoy the new ride.
Ken
Old 04-05-2013, 08:05 PM
  #168
blkz06's Avatar
Default Missing something
I have a 1990 YJ and am picking up a 2002 Chev 4x4. Why not just use the entire GM system (motor,tranny and transfer case for the swap. The truck has a 4.8l engine, 4l60E tranny and GM transfer case with floor shifter
Old 04-05-2013, 09:14 PM
  #169
Good question. It's been a while since I was in the planning stage of this swap but here's what I remember:
The YJ front axle requires a driver side drop transfer case. I believe the powertrain you are referring to has a pass side drop. If you are also swapping the front axle then you should be fine.
I also wanted to be able to reuse my stock driveshafts. By building the transfer case the way I did I was able to do so and save a few hundred dollars. I was also able to make use of the stock jeep speedo which saved some more dollars.
Ken Wolkens
Old 04-05-2013, 11:58 PM
  #170
LS1 TJ's Avatar
By far the best LS swap for a Wrangler. I logged 19 miles of snow plowing this winter with my 98 TJ LS6/4l60e swap. That was just my driveway.
Old 04-07-2013, 02:06 PM
  #171
blkz06's Avatar
Smile
Thanks for the reply - I picked up the 2002 Chev 4X4 yesterday and will start tearing it apart this week. This will be my 4 conversion - Ive done a 75' Monza - V6 to V8 then did a 88 S-10 4 cyl to 400 hp V8 ( ground up custom) then did a V6 Fiero to a 420 HP V8 and now the Jeep.
Your posts have been very inspiring and I really appreciate your detail and photos.
I need a good plow truck and I think this will be the trick, as well when out in the bush the V-8 will make it alot more enjoyable.
Old 04-27-2013, 11:33 PM
  #172
silver04goat's Avatar
All i can say is Docked Wage you are one handy guy!! All the fabrication and part matching is amazing. I dont have a jeep yet but really want one soon. Im thinking about doing a 5.3 or a 6.0 in it. After reading about traction issues and such i wonder if 6.0 may be too much for it? Was also thinking about a 5.3 with a supercharger or low boost turbo. Mine would not be offroaded primarily a daily driver as i want to keep miles off my pontiac gto but still have something fun to drive. This post had me glued to it i just kept clicking next page!!!
Old 04-28-2013, 08:07 AM
  #173
Thanks for the compliment but I have to say that I found most of the info for part matchups on the web. It was scattered on various sites around the web so I figured I'd put it all together in one place.
As for a 6.0 being to much it's really only another 25 HP. Now a turbo or a blower would make it an unruly beast in my opinion. Then again this is the first time in my life that i actually think that something has more than enough power.
Not saying that it's the fastest thing out there but as mine sits, it will outrun most of the stuff on the street because of the power to weight ratio.
If you have other questions let me know and I'll try to answer as best I can.
Ken Wolkens
Old 07-28-2013, 02:30 PM
  #174
cjjohn's Avatar
Docked Wage,
Another compliment on your write up! I have it bookmarked for reference. I have my 5.3 in my CJ7, and it's off for exhaust this week, as well as new drive shafts. I'm in CA so I am keeping it smog legal, the tip about fly cutting the manifolds is great and that may be an option. I also have a set of Pacesetter headers that may be used after a little fitting. Thanks for all the info!
John
Old 07-28-2013, 07:38 PM
  #175
Thanks again for the compliment. Feel free to reply here or PM me if you have any other questions.
Regards, Ken Wolkens
Old 01-08-2014, 12:01 PM
  #176
VRodAJ's Avatar
I can't seem to find how you got the stock speedometer to work. Could you steer me to the post that explains how you did it.
Old 01-09-2014, 07:38 AM
  #177
Since I used the back half of the Jeep 231J Transfer Case I kept the stock speed signal generator in place. To make it function I tapped the LS ECM for a 5 volt source and ground to power the sender. Then I sent the signal to the Speedometer.
Here's the pinout for the Stock 92 Jeep VSS.
Attached Thumbnails Jeep YJ 5.3L swap (completed)-jeep-vss-pinout-1.jpg   Jeep YJ 5.3L swap (completed)-jeep-vss-pinout-2.jpg
Old 01-09-2014, 09:12 AM
  #178
ijimmy's Avatar
Correct me if im wrong but , doesn't the 8.8 rear end have a tone ring that can be used for vvs
Old 01-09-2014, 04:16 PM
  #179
It does and I looked into using it but there was an issue with the tooth count.
Also its a Variable Reluctor and in this case the speedo needs a digital signal.
Old 01-13-2014, 03:31 PM
  #180
VRodAJ's Avatar
I'm not really good at wiring, could you explain this a little more. What wires connect to where and where did you find the 5 volt source and ground on the GM ECM. I had novak do my GM harness and ECM.
Thanks for the help
AJ
Quick Reply: Jeep YJ 5.3L swap (completed)
