Project: LS197
#85
Can not believe I found this wrote up!! I'm currently putting an ls in my 06 gt and I thought I was the first one! I couldn't find any info on anything so my build had been "slow" if you will. Lol but good stuff man this helps out so much for my build!
#90
Here's a few pics I took along the way:
Below is the pic of clutch hose for the stock Mustang Master cylinder to the GM slave.
The motor mounts I built myself. Not pretty, but very stout!
Below are pics of the stock GTO shifter, and how it lines up perfectly with the stock Mustang shifter hole:
Since the engine is actually a stock L92, with LS3 intake...I'm using the L92 water pump and throttle body. They barely fit with the LS3 intake, but they do all fit!
Here is the stock Mustang trans crossmember. I couldn't use it, but it lines up nearly perfect. My header guy fabbed up the tubular trans mount in the second pic.
I don't have any pictures of the headers out of the car, but they are 1 7/8" 304 stainless.
Here's the iPad mounted in place of the radio. The ECM and fuse box are behind the iPad, mounted to the IP carrier.
Here's the motor installed and ready to run:
#91
