My guide to installing a mech coolant guage on the car. PICS!!!
You will need:
1: Gauge
2: Drill
3: Drill bit 7/16 (37/64)
4: Tap 1/4-18 npt (3/8-? Npt)
5: Allen wrench 8mm
6: Box end wrench 1/2-12pt
7: Socket for your fitting may vary by manufacturer. My was 3/4
8: Compressor
9: Air hose
10: Extra quick connect air fitting
1. Drain the coolant.
2. Remove the #8 plug wire.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0581.jpg)
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0582.jpg)
3. Remove the plug under the #8 coil.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0583.jpg)
4. Turn the pressure reg on air compressor down to about 15psi.
5. Install an air fitting on the air hose.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0578.jpg)
6. Place air hose in the top of the radiator and block off around the hose with a rag.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0579.jpg)
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0580.jpg)
7. Drill the hole for the fitting. Be sure to drill a straight as possible. WEAR SAFETY GLASSES the air will blow the shavings out.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0586.jpg)
8. Tap the hole. WEAR SAFETY GLASSES the air will blow the chips out.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0587.jpg)
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0588.jpg)
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0589.jpg)
9. Thread in fitting with sealant.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0590.jpg)
10. Install gauge probe.
![](http://i406.photobucket.com/albums/pp147/71ANTICARB/Temp%20gauge/IMAG0591.jpg)
11. Fill coolant and check for leaks.
Mounting of the gauge and running of the capilary tube is on you guys.
1: Gauge
2: Drill
5: Allen wrench 8mm
8: Compressor
9: Air hose
Tip.. if you dip your drill bit and tap in grease. The Grease will collect the chips and shaving while drilling and using the tap. Allso slow down the speed a bit to let the grease do its job of collecting the chips/shavings.
Clean and reapply fresh grease to the drill bit / Tap if it gets loaded up.
I have and others have used this, it works well..
BC
BC
I used the sensor on the driver front head for the PCM, but my car doesn't have a guage(too old). I put the mechanical guage in so I have a guage.
