LQ9 408 in 1970 Trans Am
Hi, swapping a 408 LQ9 with L92 heads in my 1970 trans am. i am going to be using the shaker hood so i was wondering which intake manifold is the tallest? The carbureted victor jr, performer rpm or the GMPP? this is crucial due to the shaker scoop clearance.
Thanks for your help.
You have a couple of options....you can go with the higher intake and use a drop-base like the blockers or WFO performance one or try out the RPM and possibly get a stocker to fit.
Either way you probably aren't going to get a perfect solution. I would probably try the Vic Jr and go with a Blockers/WFO base and see where that lands u.
Dave
Dave
They do have a super Vic intake.
here is a post showing the differences
https://ls1tech.com/forums/carburete...super-vic.html
Dave
Dave
just discovered the victor jr. is 1" taller than the GMPP intake. Does anything think the shaker will still clear with the victor jr with a WFO drop base unit?
Good info, now I need to find out how much taller a vic JR is to the other choices out there! If you had the time I'd love to get a measurement from the valley pan to the top of the carb? Edelbrock I think has the manifold hieght so even the carb height would be helpful for comparison!
Need new pics man!
Need new pics man!
