6cyl to 6.0 conversion....
Old 09-10-2011, 06:26 AM
JLoosh's Avatar
Default 6cyl to 6.0 conversion....
would it be possible/practical to get a 6cyl fbody and try to stick a 6.0...or even a ls1 in it....or would it be a headache that I would wish i would never had tried?
Old 09-10-2011, 06:58 AM
82cetuner's Avatar
it wouldnt be to hard but you pretty much need all the same stuff you would need if you were to put a ls1 in an on ls1 car.
best bet is to find a pullout with the engine, harness and computer, get as much of the parts as you can off it.
but if you dont own a f-body yet and you want a V8 then go get the V8 cause it will be cheeper than trying to buy a v6 and doing the swap
Old 09-10-2011, 08:59 AM
Starz T/A 17's Avatar
As mentioned above if you already have a V6 car or a cheap roller and can get the engine and accessories fairly cheap I would go for it. The 6.0 will fit just as well as a LS1 does but my main concern about the swap would be the money. Projects like this tend to nickel and dime you to death. So I would spend some time thinking about EVERYTHING you will need to do the swap
Old 09-11-2011, 07:32 AM
Old Geezer's Avatar
try a search.. AIRC, this has been discussed B4. Might have some info to save you some headaches....
Old 09-11-2011, 05:00 PM
the_merv's Avatar
I did..
https://ls1tech.com/forums/conversio...-6-7l-t56.html
