Wiring thoughts on powering pcm relay or no
Well im redoing some of the wiring in my car and getting rid of some stuff that dosent need to be in there.
when i turn my key on it powers up the (key on power relay) that relay then powers my fuse block and also powers my other relay that turns on my (pcm relay) which turns my pcm on.
my harness has one wire to turn on the pcm. whats the best way to give that wire power.
from ignition switch to pcm
ign switch to relay to pcm
from key on fuse block to pcm
Just remember that the PCM needs to types of power source.. a) Constant +12volt and b) Key/IGN +12volts.
Look at the fuse box or chart that usually is on the lid of the fuse box.. that would tell you what is the fuse AMP size to use.
And as everyone agreed, the Key/IGN should power a relay that will feed power to the rest of the fuse box fuse and relays.
Thread revival from the dead!
Pocket, I sent you a PM about your schematic above...but it may help others in the future.
What size wiring do I need from my battery to my IGN relay, battery to PCM fuse, and battery to fan relay?
I know fans typically draw quite a bit. I guess I'm concerned about all of the fuses (except the PCM fuse) getting their power from the IGN relay.
Everything I've read has shown 14AWG is sufficient, so that's what I bought (and terminals to fit). But, when I researched 14AWG (after the fact), 20AMPS is on the limit for it.
Am I safe running 14AWG from my Battery to the IGN relay?
Am I safe running 14AWG from my Battery to the PCM fush Batt+?
Am I safe running 14AWG from my Battery to the Fan relays?
I am basically setting up my fuse box EXACTLY like the schematic. The only thing I'll do differently is run a single speed fan (if I even run a fan, still not sure, I may use the clutch fan).
Thanks,
Shawn
Thanks,
Shawn
Ill type it out again for everyone's benefit
Everything from the batt is 12ga
The jumper connecting the L/R strips is 12ga
All relay high power in/outs (30,87) are 12ga
AC is all 18ga
Rest is all 18ga
14ga is not enough to run the engine and power the fuseblock
Just for reference, stock used 16ga in/out on the FP relay. I use 12ga for consistency, plus alot of aftermarket pumps will overload 16ga cable such as the bosche 044
AC is all 18ga
Rest is all 18ga
Pocket,
Thanks for your info and your time. Your posts are invaluable to us newbs.
I went out and bought 12awg while I waited for a reply as I assumed the 14awg was too little. I couldn't make the 10awg work well (terminal ends wont hold it well, so I didn't even try to solder it).
Thanks again!
Shawn
Thanks again!
Shawn
I've got another question:
My 6L80E has a battery (+) wire. If I need constant Battery + voltage, would I be safe connecting this in line with my PCM/Fuel relay fused battery (+) with the 20AMP fuse?
I'm not sure if the 4L60/80 required a Battery+ for their TCM...but my 6L80 has it (as far as I can tell from the schematics).
Thanks
Shawn
Thanks
Shawn
