350Z LS2 Project
In a few months, I will start a first V8 swap in a 350Z in Spain. It's for this reason, I'd like you would help me with some doubts I may have.
The next month, I'll recieve a LS2 from a wrecked Corvette. This engine doesn't have neither tranny (T56), ECU, nor wiring harness. These last, as you can see in the photos, they have just been cut.
At this moment, I've contacted with Justin from SIKKY to talk about what I need to make the swap, but I still have some questions.
I can see in the Sikky page, two headers measures. 1 3/4 designed to work under 500hp and the other, 1 7/8 for working +500hp. My idea is to upgrade the camshaft during the swap process to obtain around 500hp.
My doubt is if there is any problem in mounting 1 7/8 headers with less than 500hp, which I'll add later with a compressor or any other methods.
Another doubt, there are some electronic parts which I'd like to know if may keep or I'll lose them, such as the ABS, Cruise control, dash board, airbags, throttle, etc.
A final question is about ECUs. I don't know if I need to buy the LS2 ECU and an aftermarket, just the LS2 with 350Z or what? I'm just confused
Thanks in advance
Jose.
P.S. If anyone speaks Spanish it'll be great!
Sikky Mount Kit ( do not buy the Master Cylinder ) Sikky.Com
Wilwood 1" Bore Master Cylinder Summitracing.com
E40 ECU with VATTS and skit shift deleted. Ebay seller from new york 250.00
Dual Core 3" Radiator from summit.
Can bus from hinsonsupercars or autometer tach with 680 ohm 1.4 watt res.
High torq mini starter
Wrap headers with thermal wrap and starter due to LTH.
Thatshould get you started. Feel free to ask questions if you need help durring your build.
The chasebays option, Justin had already told:
About the E40 ECU and VATTS, I don't know about it, and I'll look for information.
About High torq mini starter, I don't understand this.
About the headers, What is LTH??
Thanks for everything.
Jon
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Jon
PSI
Ebay Store
Mini starter wraped because heat soak from the long tube headers.
Just go through chase bays for the harness, they have a great looking harness. I got mine from sikky and thinking about buying one to replace it from chase bays or do it myself. I have a 406 stroker LS2 in my G35 and it way too much fun to drive.
Jon
PSI
Ebay Store
https://ls1tech.com/forums/introduct...ser-spain.html
I saw the Summit page and I can see the dual core radiators, master cylinders, stsarters... and I don't know what is the the good choice.
Wilwwod Master cylinder. Is good?
http://www.summitracing.com/parts/WIL-260-6766/
CSR Mini High Torque Starter. Is good?
http://www.summitracing.com/parts/CSI-109S/
The list of Dual core Radiators. What I have to take?
http://www.summitracing.com/search/?...Radiator&dds=1
Thanks in advance.
P.S. When this doubts are solved, I'll have the Parts list finished and I'll copy&paste here.
http://www.summitracing.com/parts/MSD-5096/
Sikky.com Master Cylinder will be fine. Just do the drill mod with 4an stainless lines.from MC to T56 and 3an for bleeder valve.
For a little inspiration you can take a look at these links:
http://fatlace.com/life/welcome-home/
http://fatlace.com/life/350z-ls1-dri...most-complete/
http://fatlace.com/life/stage-4-phas...ome-part-love/
If you click on the authors name at the top right of the article you can view more parts of the build that he has written. This guy has been working on his LSx 350Z for a while now. He had a lot of custom fab work done to the car due to it being a drift car but just giving you something to look at. He also lists all of his parts/prices at the bottom of the page giving you an idea of how much you will spend on certain things. Good luck with the build man. Keep us updated.
Fafonfoe, sorry but I dont' understand...
First, you said this...
About this
So that I do, buy the SIKKY master cylinder or not?
Another question. What is the correct fuel pump?
http://www.summitracing.com/parts/VPN-GSS341/
http://www.summitracing.com/parts/VPN-GCA758-2/
project! Big props to you for trying this - good luck with it!!
