Help On LS2 Swap into G35
Old 05-07-2012, 04:14 PM
DCNightLife's Avatar
Default Help On LS2 Swap into G35
Looking into buying a LS2/T56 Engine and Tran and putting it in my G35. I see alot of folks are doing this with the G's and Z's. I was wondering if anyone one that has done it could answer a few questions for me.
Will I be able to use my stock gauges on my G35?
Will I be able to use my AC/Heating controls?
I've read up on a few threads on those that have done it, and it looks clear cut.
But I really would like to know if there is any major surprises I need to be ready for?
Thanks for your time?
Old 05-07-2012, 07:06 PM
gnx7's Avatar
There is a great button at the top called "SEARCH."
I typed in 350Z and came up with this in 5 seconds.
https://ls1tech.com/forums/conversio...ore-turbo.html
Old 05-08-2012, 08:44 AM
Thanks I see your post still doesn't answer my question nor does the link you provided after reading it 3 times. With all the folks that have done the swap on the G's and Z's can someone tell me if the stock gauges still work??
Old 05-08-2012, 08:55 AM
Eastern Regional Coordinator
CTSVBiggie's Avatar
Contact they guys at sikky. If via your name you are in DC... understand they are local and go to Summit Point all the time. Talk to them and get to know them. Nothing like knowing the shop that does em all the time.
Old 05-08-2012, 10:34 AM
RPM Graphics's Avatar
there's a guy on here that has done the swap. pretty badass if you ask me.
Old 05-09-2012, 08:45 AM
Thanks chief, will do.
Quick Reply: Help On LS2 Swap into G35
