oil sending unit
The one with the tap still in it is the original sending unit. It was broken anyway. The other one is the oil cooler bypass from near the oil filter. I drilled and tapped both for 1/8 npt. This way you can use whatever sender you need.
Sorry about posting my problem hear im new to the forum thing and have run out of options im having problems with oil gauge abs inop and some sorry of drive train noise all after a motor swap been through everything read every book replaced almost everything possible can anyone help
