67 Camaro swap, project "belly button"
#182
More progress
Motor is finally mated back to transmission and installed in the car. Hope it's the last time and I can start plumbing brake/fuel/clutch hydraulics. Still need to install gas tank, rear calipers/rotors and most importantly the AAW classic update wiring kit. Might have a ship so the AAW kit but if I do that will likely be the last step do they can connect everything. Getting close...
Beauty and the beast
#183
Thanks bandit! I hope to keep the momentum rolling through summer. Didn't need to notch the grand just minor cut around the plastic cover at the rear of the LS1 alt. I have an AAW classic update kit that needs to be installed and I also have a Rick's tank with vaporworx set up that needs to be installed. Then just run fuel lines to motor. Engine harness still needs to be sent somewhere to be modified and flash computer but I'm not quite there yet.
#184
Squeezed in some Camaro time this weekend. Tapping water pump and trying to locate the box with steam port pipe in my garage ate up about two hours, lol. Happy to install and torque all front accessories... Minus power steering pump. Progress is progress...
#186
The vent should, in my opinion, route uphill so air can purge out of the system by gravity while filling the coolant system. In the OE systems it's routed to the top of the radiator. Lots of people have done what you've done without problems, but I suspect it's less effective.
#188
Little progress today. Installed brake and fuel hardlines, dug out parts/brackets then made a to do list. Looking forward to checking this list off in the weeks to come.
#189
#190
Project belly button updates...
Progress...
DSE Hydraulic Clutch Bracket and adapter kit
Line up clutch pedal push rod outside of car
Time to blast
Semi gloss black Rust-Oleum out of spray gun not rattle can
Finished product
Pedals back in and DSE clutch plate installed
DSE booster brackets helped fix high angle of booster and master (right hand drive S-10 master cylinder.
Hydraulics hooked up
Little eB@** bling for hydraulic clutch reservoir
Doug Thorley stainless headers ready for install
Cleared steering box very well
Doug Thorley👍🏽👍🏽
Test fitting 4th gen front brakes.
Cheapo rotor will be replaced before driving
Changing knock sensors
Out with old...
...In with new
New intake gaskets
Time to start wiring this thing!
Not bad for newbie
Need to clean up this cluster and wire up.
Booster at good angle, headers and intake installed.
Time to blast
Finished product
Doug Thorley👍🏽👍🏽
Out with old...
...In with new
New intake gaskets
Not bad for newbie
#195
Good stuff. I'm sure your dad would approve! Some tools I have that might help: flywheel lock, damper puller, damper install threaded rod/nuts, degree wheel, dial indicator, push rod length checker, spring height checker, and I can't recall what else. Hope to get down your way soon to help but no idea yet when that can happen.
The following users liked this post:
MisterD (11-15-2019)
#196
#198
cam (07-24-2020)
#200
BTT because I can't believe nobody replied to congratulation you. I had the pleasure of doing it in person and I want to say this car and the builder are cool as hell. I wish mine looked nearly as nice under the hood. Look forward to meeting again after I get my six speed in.
G Atsma (07-23-2020)
