Ls/lm7 with th350 or 700r4
Well I'm back at it again, I gave up on putting the muncie onto the lm7 I've got 2 good auto transmissions a th350 and a 700r4. I was told I would need a pilot bushing? From my torque converter to crankshaft to make up for the extra space anyone have a suggestion or any expierience with this thanks.
I run a 700r4, and a TCI flexplate. The TCI came with the spacer needed to run the 700R4 torque converter, and bolted right up no problem.
There is also a GM part number for the required spacer, should turn up with a search
Martin
Martin
I was told by an old transmission guy that the 700 was much stronger than the 350. In order to make a choice there are several questions to ask. What is your rear gear ratio? I would say about 3.5:1 (or higher numbers) for an overdrive transmission. Second, do you plan on long distance or in town. Love the overdrive.
A bit of both worlds really but long distance is the priority. The diff is currently 3.08. I'm driving the car now with the orig 350 pont 2 speed powerglide, I don't mind the 2 speed as much as I thought I would so here's another one in the mix u can get a chev powerglide also, which I'm leaning towards a little more for ease of installation. On the hwy I don't think it matters what tranny I pick ultimately cause all have a 1:1 final drive I do believe? Help is greatly appreciated.
Ok cool I didn't know that, thanks. Prob go with the 700 then, just need to find the spacer for between the flex plate and converter anyone have a parts # by chance? Just out of curiosity do you know the final drive of a power glide?
