lsa blower swap?
The main accessory drive and WP are on the corvette spacing so a VVT timing cover will not clear. If you shim the SC pulley out to match a truck 8 rib crank pulley and build a custom FEAD, its feasible. IIRC, there isnt a truck spacing WP with mount bosses in it like the LS3 WP. Good luck there
#34
The following users liked this post:
General Lee 01 (06-17-2023)
#36
#38
pocket the way you doing your lsa setup will it have its on seperate belt or will it have one belt for everything?
