twin turbo 5.3 89 nissan 240sx
89 nissan 240sx
5.3 cast iron block
Comp cam custom grind 226/233 .605/.605 114+5 lsa
brian tooley dual springs
arp main cap studs
arp head studs
120lb Bosch injectors
Holly efi
Ported 862 heads with ls1 valves
Lm7 intake
High volume oil pump
4l80e transmission
3400 stall
twin borg warner s362 62mm turbos 62.8mm inducer 68mm exducer .88ar
e85 tune
5.3 cast iron block
arp main cap studs
arp head studs
Holly efi
Lm7 intake
4l80e transmission
3400 stall
e85 tune
No I'm still looking to buy one. I'm actually going to cut my tunnel out and get it fitted then put the tunnel back in. I figured it'd be easier from the top than from the bottom and putting a tunnel back in it is no biggy.
