Question on reluctor ring
Guys, I'm doing an LS swap into a genesis coupe and I am trying to resolve the tach issue being that the genesis uses can bus gauges.
This is the description of the reluctor ring directly out of the genesis service manual: "The target wheel consists of 58 slots and 2 missing slots on 360 CA (Crank Angle)"
Would this description fit the GM 58x wheel? If so, does the diameter of the ring matter or is it the number of slots that is the main issue?
My thought here is to adapt the GM 58x ring onto the harmonic balancer to pick up the signal for the tach using the genesis ECU.
The GM ECU will handle all other duties.
