4L60E questions
4L60E questions
I apologize if this is not the appropriate section for this question but here goes: I think I'm going to have to give up on getting a T56 for my project (too darn expensive) and am considering a 4L60e. Is it true that I can use one out of a Trailblazer by switching the bell housing? They are plenty of them in the local upull it yards. Are any years more or less desirable? I'm running gen III electronics (03 Yukon) so i need a compatible trans. I've also read that the Trailblazer converter stalls higher when used with a V8, is that correct?
Thanks for any "Auto" education you all can provide!
S.F.
S.F.
Hope you don't mind me adding in with another question StolenFox.
Is the Range/PRNDL switch needed? It seems most standalone harness websites don't even show it.
Not sure what your question is.....
If the Trans is from a SBC architecture vehicle, it will work but will be missing a mounting hole IIRC.
You will also need a spacer to go between the crank and torque converter. I have the same setup, 4L60E from an early rig, bolted to my LQ4. The flywheel I use came with a spacer for this reason.
Think this is what you'll need
http://www.summitracing.com/parts/su...make/chevrolet
As far as a PRND switch goes, I just have what is internal to the trans, and nothing else. I made an adapter to use the Range Rover XYZ switch, but that is nothing to do with the 4L60.
Hope this helps
Martin
Hope this helps
Martin
Hope this helps
Martin
Hope this helps
Martin
S.F.
4l60e came from the factory behind the LQ9 which is around 345hp and 389ft lbs of torque. If it is not beat to hell it will be a good trans in stock form. If you decide to throw some power into it start looking at a good build for it. If you want to avoid future problems due to power upgrades you may do down the line go with a 4l80e or 4L85E. They came behind quite a few vehicles with LS and can be had from $500-$1000 out of a bone yard.
Ahhhhh OK, got ye.
I would try for a V8 one if possible. I have "heard" there are differences in the 6 cylinder and 8 cylinder models of the 700R4 and 4L60E. I couldn't tell you 100% though.
I would guess, if you drive it right, either one will last fine.
Martin
Martin
Pages of info in the automatic trans section of this forum and a couple of resident experts there as well.The 2000-2004 4L60E's have all pretty much the same internals,the 4L65/70E
have upgraded clutches and a few other tweaks,the V6 units will do just fine behind a V8.
Alright, that clears up the 6 vs 8 question. How about production year differences? A friend of mine has a 4L60E out of a 2007 Silverado that is a builder that I can get reasonably. Will a trans that "new" that was controlled with a gen 4 PCM work with gen 3 (2003 Yukon) electronics?
S.F.
S.F.
I had a 2002 Trailblazer and the trans went at 76K miles. Those engineers are really good at making stuff last just over the warranty.
I would get a LS 4L60...better yet a 4L65....better yet, a 4L70...but I am not sure that it was offered in 2 wheel drive.
Andrew
Andrew
