Ls1/th350,Stinger, 87 Notchback build
Well deciding to go carb and running into the issues from clearance with the super Vic,stinger plate and carb it was very close. And with basically rewiring the entire car with new gauges I decided to just go ahead and pick up a new roller. Sold the 12 bolt and the car as a roller and picked up my buddies 87 notchback he already had swapped but lost interest in.
When we took the motor out of it.
After we got the fenders on and test for the hood.
Parts starting to pile in.
Picked up double adjustable uppers and tubular lowers from a buddy.
Picked up a aed 850.
Got and aje th350 crossmember.
Picked up dynatech longtubes and an X pipe with mufflers.
We put the motor in and man it took no time at all! I will take a fox body vs an fbody any day and we are really good at having it in and out the bottom lol.
Used the factory fbody hoses and and radiator/fans. Used the factory fox body radiator brackets.
Had a bad rusted drivers floor pan. And got a new one with the car. Cut the old out.
Got the new one fitted in!
Here's the last pass on the car from cruising the coast.
Facebook Post
Finally washed the car!
Trans cooler hooked up.
Aero motive fuel pressure regulator.
Got the carb and everything hooked up.
Got it fired up.
View My Video
Got the bumper mocked up gotta paint the trim and put it on.
Trimmed the ashtray and mounted my pro ratchet stealth.
Got it fired up.
View My Video
Good looking build, The car should be a blast when it's done. Are you still running the super vic? Do you know what size the cowl is and if there is room to run an air filter under it? I have a 93' coupe I am building and I'm going to use a vic jr to start with but I want to make sure I will have enough clearance for if I want to go to a Super Vic later on. Thank's
Yessir same set up just going carb. Main plans are to cruise and track the car, pretty much done with running on the street. Cars getting a 10 pt cage,kirkeys and some new carpet in the interior still, don't want to be rolling around in a tin can lol.
https://www.facebook.com/Barneyz28/v...4437639240212/
Got my fans wired up and all the wiring hidden.
Picked up some draglites with tires for $400.
The look the cars gonna have with the black draglites on it.
Finally got my s&w 10 point cage.
Picked up some summit seats with covers cheap and also ordered a Holcomb bracket.
Ordered some perfect match style paint and painted the gas cap and fender trim turned out great!
And final got my tinted headlights.
Ordered spherical bushings for the upper part of the 8.8. And wound up getting some 90/10's and a crap load of other stuff for cheap locally. So just gotta find some time to make it home and get it all put on.
Got my glow shift gauges,15 gallon fuel cell and my 1 gallon fuel cell for nitrous and my strang single adj. rear shocks.
Got the strange shocks on and one of the upper spherical bushings in and one upper adjustable control arm on.
Got the nitrous stand alone mounted.
Got the 15 gallon fuel cell in just have to clearance the spare tire well some and bolt it down.
Ordered some eBay single chamber mufflers too should sound good. Just waiting on my 8 an line to get here from China and I can hook up the Holley blue and run the new lines.
Thanks man I Appreciate it I got it as a roller from a real close friend him and his uncle did a damn good job on the paint and he put a lot of time into it replacing all weather stripping and stuff so I owe a lot of the way it looks to him, I just threw wheels and a motor in it lol! I'm about 3 hours away from the car for work so I work on it as much as I can when up home once in a blue moon hopefully having it going soon enough!
