e67 Standalone ECU?
e67 Standalone ECU?
Hey guys, sorry if this has been asked before... I've been searching, but no answers yet.
I have a Gen IV 5.3 that I am swapping into a Porsche 944. I'm a bit confused by the ECU though. It seems I can get an E67 ecu and harness from a junkyard relatively cheap. Does it matter what it comes from? How do I go about making the ECU standalone? Does it matter if it's from a manual/auto vehicle? And will it work fine with the Porsche transmission? It seems the Porsche guys often install a 40 tooth reluctor wheel and speed sensor.
Thanks!
Thanks!
If you currently don't have any electronics, consider this:
https://holley.com/products/ls_power.../parts/550-603
A lot more flexibility than OEM, although you will need to swap to a cable TB.
Andrew
Andrew
The PCM doesn't matter as much as the calibration. One problem you will find is you really need a PCM that came from a Gen IV vehicle and depending on your goals, a decent calibrator to program it. The PCM doesn't care what hardware you have, as long as it has the parameters to run it.
In short, a E67 or an E38 could be used on the same engine IF the calibration and harness was correct for the engine. Both PCM's you listed use different connectors on the PCM side so you need to commit to one. The E67 has some benefits in a factory supercharged setting over an E38 but in a swap the benefits aren't as great.
When I buy engines I make sure to get the PCM and harness together. If you don't you spend a ton of time and money trying to piece a bunch of stuff together or buy the right parts and usually have problems if they don't match.
The Holley setup isn't cheap - but it's self learning which saves a lot of time and potentially money if you have the need. Another benefit is the Holley system is all new. However, I'm not sure it can control an electronic transmission. If you can buy all the parts you need used plus have the ability to do the work, you will be money ahead. If you want a nearly turn key system, it's Holley.
I'm not worried about tuning it on my own, or doing the wiring, etc. I was just confused by the ECUs, and what I'm able to flash to/from. It seems then, the E38 is easier to find, so I just need an E38 and harness. Then a thottle body and pedal to match the base operating system I choose.
As far as using it with a manual transmission, will I need a base operating system to match the transmission type, or would this simply be a setting to switch in HPTuners?
