Alternator wiring
Alternator wiring
I know it's been beat to death, but I can't find much on a 4 wire alternator. I have a DR44 alternator with a 4 pin connector I need to wire up in my Nova. For pin "B" do I use the original brown wire that goes to the dash lamp AND a resistor, or just the brown wire without the resistor?
If you have a dash lamp, wire the L terminal through that. If there is no dash light, then you have to use a resistor. Also, wire the S terminal to your main power distribution point. This will allow the alternator to sense (hence S terminal) the load on the system and adjust output accordingly. Without the S terminal you will experience voltage drop as more components are turned on (coolant fan, lights, etc...).
Andrew
Andrew
Andrew
http://www.pirate4x4.com/tech/billavista/Wiring/Part2/
If you have the 4 pin alternator connector you will need Metripack 150 female terminals to add the S wire.
Andrew
Or you can get a pigtail with all 4 wires already terminated:
http://store.alternatorparts.com/c13...connector.aspx
Just remove the 2 that you will not be using, but make sure you use cavity plugs to keep moisture out.
Andrew
Andrew
