Lt4 mounted in 69 camaro
#44
Nice work OP. As a general note of information to those interested in doing this swap, the engine bracket mounting bosses on the LT1/LT4 engines have a 3/8" greater stand-off height, on either side, from the center line of the engine than the mounting bosses on the LS engines do. This makes achieving a low installed engine height even more difficult than it has been with LS engines, when using flat swap plates with the old-school Chevy mounts and the factory frame stands. This discovery was made recently when we overlayed the LS and LT engine models in our CAD system.
#46
Yes. Vvt
#48
Holley will soon have a swap pan for the Gen V engines that will allow easier swapping into older cars. It's based on the 302-2 pan geometry but for Gen V engines. I'm sure swap kits are not far behind.
Andrew
Andrew
#49
I may do the dry sump model and that will eliminate the pan issue.
#52
#53
#54
Break in - contemporary engine/low tension rings makes it easy. Check to sure no leaks, no untoward noises, pressures/temps look ok. Try not to let it idle for extended periods - drive it. During the first 20-30 minute drive as many times as you can - accelerate up to 3500-5000 rpm, and then close the throttle for a "hard" deceleration....that will help seat the rings. That's it. Drive the car. I like to do an early oil/filter change at 500-1000 miles and cut the filter open.
#57
I mounted it in the front right corner. In order to make more room I relocated the battery to the trunk and used the petersons ls7 dry sump tank. It actually fit pretty good
#58
More info please. What are your thoughts? I do take it you have it broke-in all ready.
#59
Yes I have it broke in. The motor has very good street manners but when given some foot all hell breaks loose! It's really exiting to drive and the screaming sound really turns heads around here.
I've been thinking about putting the oversized drive pully on it and getting a good tune for it.
In two weeks my dad and I will be going to the drag strip and will see what it can do. Should be interesting
