Lt4 mounted in 69 camaro
Old Mar 5, 2016 | 07:18 PM
Chandvogt's Avatar
Default Lt4 mounted in 69 camaro
Well we got it sitting in place today! Lots of work to go...
Old Mar 6, 2016 | 08:36 AM
Jimbo1367's Avatar
Looks good. Any picss or details of the engine mounts and the block mounting location/layout?
Which engine did you go with? Wet or dry sump? pics of the oilpan? These engines a such a great deal IMO.
thanks,
Jim
Old Mar 6, 2016 | 10:03 AM
Chandvogt's Avatar
My engine is the dry sump. I think they are great deal also. I didn't grab any more pics then that but I will for sure.
I used the dirty dingo gen v adaptor plates and they worked great. I had to use the 3rd hole forward on the mount. It's about an 1 1/2" forward.
It sat in really nice except the oil cooler won't clear my steering arm. That's no big deal and gm has a block off plug for it. The stock exhaust manifold won't work either so I'm on the hunt for something that will.
Old Mar 6, 2016 | 11:05 AM
Project GatTagO's Avatar
I believe Ultimate Headers is offering a Gen 5 header for 69 F-bodies.
Andrew
Old Mar 6, 2016 | 11:47 AM
Jimbo1367's Avatar
From the pics I've seen, the dry sump pan looks like the most swap friendly pan. Does anybody now what else is needed to make a complete dry sump system? I would imagine something like a Peterson Dry Sump tank and hoses of choice. Anything else needed?
Old Mar 6, 2016 | 03:02 PM
Chandvogt's Avatar
Yup, that should about do it. I was looking at a 12qt tank. The internal pump should take care of the rest.
I wasn't sure about how the wet sumo would clear so I went with the dry sump. Lots of room. I'll try to put up more pics of oil pan clearance and mountings tonight.
Old Mar 7, 2016 | 05:01 PM
Chandvogt's Avatar
Here are some more pics...
Oil pan clearance
Firewall
Up front
Underneath looking forward
Old Mar 7, 2016 | 06:12 PM
Looks like you are using the "tall and narrow" Energy Suspension engine mounts. I would see if you can make it work with "short and wide" engine mounts and bring the engine down. Looks like you have the clearance with the pan and a lower position will be better for driveline angles.
Andrew
Old Mar 23, 2016 | 09:32 PM
piratebaseball's Avatar
Finally somebody is swapping in a first gen lt4 so I don't have to be the guinea
pig. Please keep pics and everything else coming. What trans did you go with?
Old Mar 24, 2016 | 01:40 PM
Jimbo1367's Avatar
I wish I had the spare cash to be the guinea pig. This will be a intensly followed build!
Old Mar 24, 2016 | 08:05 PM
I noticed that Howell EFI is now making standalone wiring harnesses and computers for the lt4 swap. The wiring harness is for 6l80 and 6l90 automatic transmissions and manual transmissions. I looked at them today. Seems to be very well put together.
Old Mar 25, 2016 | 01:15 PM
Jimbo1367's Avatar
CPP has a LT4 harness kit out all ready IIRC
Old Mar 25, 2016 | 04:25 PM
Chandvogt's Avatar
Yeah it's been a little challenging but not too bad. I went with the cpp harness cause holly didn't have it out yet. Still waiting on headers that are being made by ultimate headers(thanks Andrew). This weekend I'll be finishing up the wiring and putting in the Peterson ls7 oil tank if I have time. If there is any specific pics anyone wants me to grab just let me know. I'll be working on it all week end.
Old Mar 26, 2016 | 08:57 PM
Jimbo1367's Avatar
How about a side pic of the oilpan? Holley will have the DI version of the ECM that is out. Seen it yesterday on the net.
Old Mar 26, 2016 | 09:56 PM
Are you going with an auto or six speed Trans like a t56 magnum? Also, how do you plan on running your accessories and will you have AC?
Old Mar 28, 2016 | 06:41 AM
Chandvogt's Avatar
I'm using a Muncie m23 built by Midwest Muncie. But plan on a 6 speed in the future.
I got the accessory drive kit from cpp. It mounted up easily except for the a/c pump. My car is non a/c anyways so I had to build an idler pulley to put in place of the pump.(anyone looking for a 6 rib a/c pump?)
Old Mar 29, 2016 | 10:46 AM
redrog's Avatar
what are going to be doing for fuel delivery from tank to the mechanical pump i am getting ready to do the same swap this summer just waiting for someone to follow and piece things together
Old Mar 29, 2016 | 12:04 PM
Chandvogt's Avatar
The pump requires 72 psi of feed and I have a areomotive stealth tank that should deliver everything I need. So I'll have a pressure regulated set at 72 and return it back to the tank.
The only thing I'm wondering about is the cpp harness I have has a fuel pump system integrated in it. I'm not sure what or if I have to do anything about that.
Old Mar 29, 2016 | 01:03 PM
redrog's Avatar
i have a stealth with aeromotive 1000a pump this supplied by ricks about 5 years ago to run my 650 sbc its a full return system but i have been lead to believe that it won't work which i have hard time believing! you and i are going to have to share notes
Old Mar 30, 2016 | 09:04 PM
71buickfreak's Avatar
My lt1 is in transit, I went with the wet sump. Wondering if that was a bad idea. Going into a 71 Buick GS.
