Power steering lines with Corvette ACC drive and Jeep box
Just checking if someone has some part numbers that worked for them. I am running the Vette accessory drive, and the Jeep Cherokee box. The stock one is so long it goes from drivers to passengers side...... Thanks in advance!!!
I used one for a 78 camaro when I did the ls and Jeep box swap on my 1967 Chevelle. It has the truck accessory drive, but the line is plenty long enough. It is ugly though, and I will do as suggested above, and go to AN eventualy...
If you have a hydraulic shop near by you can also have custom hoses made. I have one shop locally that does great work. I like to fab my own brake hard lines for custom routing and I can bend and flare tubing, but I always farm out the custom high pressure hoses.
The only down down sides are 1 it usually costs more than an off the shelf hose and 2 if a custom hose ever fails you usually have to wait around for a new one.
The Jeep boxes use metric o-ring fittings, such I believe are the same as the C5 fittings. I am almost positive that I have heard of people using the stock C5 pressure hose. The return is low pressure so you can fanricobble something together, maybe even a stock C5 return hose.
C5 pressure hose. The fittings look right.
https://www.rockauto.com/en/moreinfo...380024&jsn=437
Andrew
Andrew
The stock return hose from the vette will work. Holley sells an adapter for the vette pump to change to -6 an . They also sell an adapter for the box. Then u just need a short line. This is how I did mine in my 83 cutlass
Very true on zero hose failures, but wanted to mention it as a potential negative. You can spend hours (days) going back and forth to the local auto parts store or do a one-and-done to get a custom hose made. I prefer the latter. Unless it’s for custom brake hoses, in which case I’m calling Kore3.
I've used the high pressure -6 Teflon line on the pressure side Then standard -6 on the low pressure return side. O-ring -6 adapters screwed into the Jeep box. Has worked well for over 10 years.
