Truck pin outs
This is from a 2002 silverado 5.3 (I cant recall if the first 80 is the blue or the red, but you can figure that out real easy)
1 Ground BLK/WHT
2 Ignition LT GREEN
3 Inj 3 PKN/BLK
4 Inj 2 LT GRN/BLK
5
6
7
8
9
10
11 KS Signal LT BLU
12 CKP DK BLU/WHT
13 Req torque ORG/BLK
14 serial data ORG/BLK
15 serial data DK BLU/WHT
16
17 range b DK BLU
18 range c RED
19 ignition PNK
20 B+ ORG/BLK
21 Ref low YEL
22
23 sens gnd PPL
24
25 HO2S LO TAN
26 HO2S LO TAN
27
28 HO2S LO TAN/WHT
29 HO2S LO TAN/WHT
30 Coolant level LT GRN
31
32 PRND A BLK/WHT
33 BRK SW PPL
34 PRND P WHT
35
36 Inj 1 BLK/WHT
37 Inj 6 YEL/BLK
38 Lift Dive sig PNK/WHT
39
40 Ground BLK/WHT
41 Ground BLK
42
43 inj 7 RED/BLK
44 inj 4 LT BLU/BLK
45 +5V GRY
46 +5V GRY
47 +5V GRY
48 +5V GRY
49
50
51 KS Signal
52
53 sens gnd
54 sens gnd
55 EGR input
56 Fuel Comp Sig
57 B+
58 CLS 2 Data
59 CLS 2 Data
60 sens gnd
61 Ref low
62
63 sens gnd
64
65 HO2S HI
66 HO2S HI
67
68 HO2S HI
69 HO2S HI
70 Oil Level
71
72 PRND B
73 CMP
74 ECT sig
75 Ignition
76 inj 5
77 inj 8
78
79 3-2 SS
80 Sens rtn
1 Ground BLK/WHT
2 TCC PWM BRN
3
4
5 Delivered Torque TAN/BLK
6 PC SOL HI RED/BLK
7 EGR Control RED
8 PC Sol Lo LT BLU/WHT
9 Fuel Pump DK GRN/WHT
10 RPM out WHT
11 Recirc Sw DK BLU
12
13 Cruise Eng LT BLU/BLK
14
15 Gen L BRN
16 4WD Low GRY/BLK
17 AC REQ DK GRN/WHT
18
19
20 VSS Lo LT GRN/BLK
21 VSS High PPL/WHT
22
23
24 TP Sig DK BLU
25 IAT SIG TAN
26 Ign Ctrl PPL/WHT
27 Ign Ctrl RED
28 Ign Ctrl LT BLU/WHT
29 Ign Ctrl DK GRN/WHT
30
31 MAF SIG YEL
32 MAP SIG LT GRN
33 Recirc Door DK GRN
34 Evap Can DK GRN/WHT
35
36
37
38
39 Ign Feed RED
40 GND BLK/WHT
41 EGR GND WHT
42 TCC SOL TAN/BLK
43 A/C CLU DK GRN/WHT
44
45 EVAP Vent WHT
46 MIL Ctrl BRN/WHT
47 2-3 SS YEL/BLK
48 1-2 SS LT GRN
49 VSS Out YEL/BLK
50 VSS Out DK GRN/WHT
51 TFT Sens Sig YEL/BLK
52 Gen F GRY
53
54 Fuel Lev PPL
55 CYC SW in DK GRN
56
57 SENS GND BLK
58
59
60 REF Low BRN
61 REF Low BRN/WHT
62 PRND C GRY
63 TRANS RNG A PNK
64 Fuel SIG CTRL DK GRN
65
66 IGN CTRL PPL/WHT
67 IGN CTRL RED/WHT
68 IGN CTRL DK GRN
69 IGN CTRL LT BLU
70
71
72
73
74
75
76 IAC COIL HI LT GRN/WHT
77 IAC COIL LO LT GRN BLK
78 IAC COIL LO LT BLU/BLK
79 IAC COIL HI LT BLU/WHT
80
1 Ground BLK/WHT
2 Ignition LT GREEN
3 Inj 3 PKN/BLK
4 Inj 2 LT GRN/BLK
5
6
7
8
9
10
11 KS Signal LT BLU
12 CKP DK BLU/WHT
16
17 range b DK BLU
18 range c RED
19 ignition PNK
20 B+ ORG/BLK
21 Ref low YEL
22
23 sens gnd PPL
24
25 HO2S LO TAN
26 HO2S LO TAN
27
28 HO2S LO TAN/WHT
29 HO2S LO TAN/WHT
31
32 PRND A BLK/WHT
33 BRK SW PPL
34 PRND P WHT
35
36 Inj 1 BLK/WHT
37 Inj 6 YEL/BLK
39
40 Ground BLK/WHT
41 Ground BLK
42
43 inj 7 RED/BLK
44 inj 4 LT BLU/BLK
45 +5V GRY
46 +5V GRY
47 +5V GRY
48 +5V GRY
49
50
51 KS Signal
52
53 sens gnd
54 sens gnd
55 EGR input
56 Fuel Comp Sig
57 B+
58 CLS 2 Data
59 CLS 2 Data
60 sens gnd
61 Ref low
62
63 sens gnd
64
65 HO2S HI
66 HO2S HI
67
68 HO2S HI
69 HO2S HI
70 Oil Level
71
72 PRND B
73 CMP
74 ECT sig
75 Ignition
76 inj 5
77 inj 8
78
79 3-2 SS
80 Sens rtn
1 Ground BLK/WHT
2 TCC PWM BRN
3
4
6 PC SOL HI RED/BLK
7 EGR Control RED
10 RPM out WHT
11 Recirc Sw DK BLU
12
14
15 Gen L BRN
16 4WD Low GRY/BLK
18
19
21 VSS High PPL/WHT
22
23
24 TP Sig DK BLU
25 IAT SIG TAN
26 Ign Ctrl PPL/WHT
27 Ign Ctrl RED
30
31 MAF SIG YEL
32 MAP SIG LT GRN
35
36
37
38
39 Ign Feed RED
40 GND BLK/WHT
41 EGR GND WHT
42 TCC SOL TAN/BLK
44
45 EVAP Vent WHT
46 MIL Ctrl BRN/WHT
47 2-3 SS YEL/BLK
48 1-2 SS LT GRN
49 VSS Out YEL/BLK
52 Gen F GRY
53
54 Fuel Lev PPL
55 CYC SW in DK GRN
56
57 SENS GND BLK
58
59
60 REF Low BRN
61 REF Low BRN/WHT
62 PRND C GRY
63 TRANS RNG A PNK
65
66 IGN CTRL PPL/WHT
67 IGN CTRL RED/WHT
68 IGN CTRL DK GRN
69 IGN CTRL LT BLU
70
71
72
73
74
75
80
I never wrote the colors down, But I have the complete wiring diagrams for the motor, and where the wires from the blue and black plugs go and a diagram for what the wires going to the underhood bussed electrical center go to. I tried to post them but couldn`t figure out how so if you want to PM me a e-mail address I can send you pdf files of them.
