LS7 oil pan compared to F-body oil pan
Old 11-14-2005, 10:41 PM
Moderator
John B's Avatar
Default LS7 oil pan compared to F-body oil pan
Here's a peek at both pans next to each other for those interested in comparing!
Attached Thumbnails LS7 oil pan compared to F-body oil pan-ls7vsf-bodyoilpan.jpg
Old 11-14-2005, 11:02 PM
jrp
SN95 Director
jrp's Avatar
has it be confirmed or not if the ls7 dry sump is retrofit to the fbody?
Old 11-15-2005, 01:52 PM
TAF Motorsports's Avatar
I'm trying to figure out if the C6 LS2 pan will fit, It has added baffeling in
the pan. The front part of the sump looks awfuly close, nobody has come up with a difinitive answer.... does Any body have a spare C6 Pan they want to let me borrow????
Old 11-15-2005, 09:35 PM
Moderator
John B's Avatar
Try calling MORE Performance. Since they have a complete LS7 in pieces, it would be a slam dunk to fit up an LS2 pan.
Old 11-17-2005, 08:18 AM
thx I'll ive them a call today
Old 12-03-2005, 02:48 AM
Sabre002's Avatar
any new update on this I know the LS1 RX7 guys might have some intrested in this because the LS1 pans hang low in the FD's
Old 12-03-2005, 01:17 PM
cslithergo's Avatar
Here is a great place for pic reference...
http://www.hotrodlane.cc/onlinecatal...DFcomplete.pdf
Try page 82
chris
Old 12-22-2005, 02:53 PM
cslithergo's Avatar
Here is some more....
http://vorlon.case.edu/~aap8/gallery/c6z06media?page=5
Old 04-15-2006, 11:56 AM
Sabre002's Avatar
ok will the LS7 pan work on a LS1 and be able to keep the LS1's wet sump oil system? I'm looking for something to get more ground clearance on my LS1 RX7.
Old 04-15-2006, 12:15 PM
67RSCamaroVette's Avatar
will work on a LS1, but it needs the complete oiling system. not enough capacity with just the pan.
Old 04-15-2006, 12:24 PM
Bill Reid's Avatar
It isn't capacity so much as the exclusive integrated porting on the LS7 pan only for factory dry sump twin rotor oil pump.
BTW, you would also need a longer snout LS7 style crank to accomodate the twin rotor pump as well as an LS7 front cover... with cam sensor adaptor harness.
Bill
Old 04-23-2006, 08:58 AM
bluecamaroz28's Avatar
Will the LS1 truck oil pan fit the LS7 engine for those looking for LS7 engine swap in a truck?
Old 04-23-2006, 10:02 AM
Moderator
John B's Avatar
No, the front cover is different on the LS7.
Old 04-29-2006, 12:15 PM
GMW-CSL's Avatar
It would seem to me that if your pan had enough capacity (stock or modified), i.e. 7 or 8 quarts, and you did a good job of porting a stock LS2 pump or used a Melling high volume pump you would be just fine running an LS7 with a wet sump providing that your pick-up was properly positioned, your pan properly baffeld and your windage tray was effective. I don't think that the stock LS7 supply pump is of any higher capacity than a well ported LS2 or the Melling pump, is it? I understand that the scavenge pump in a dry sump system pulls a little vacuum in the crankcase which helps at high rpm but other than that it seems to me that a wet sump would work well so long as you shorten the crank to LS2 specs. and you install an LS2 front cover and pump. I'm not an expert so please correct me if I've missed something here.
Old 06-06-2006, 05:28 PM
RS_Customs's Avatar
Any more information on swaping the Ls7 dry sump onto a Ls1?
Could you use a f-body or the shorter Ls7 pan and a Melling high flow pump to get an affective dry sump system.
Anybody tried this?
Thanks
Robert
Old 06-07-2006, 04:24 AM
AceHaag's Avatar
is there anyone out there that has pics similar to this one for the other variations of lsx pans it seems to be a big topic in this forum "what oil pan should i use?"
Old 06-30-2006, 12:06 AM
Steve1969LS1's Avatar
I have the C6 pan and it's interchagable with the f-body pan. I also have pics showing the differences in size at the front of the pan.. just need to host them.
The f-body pan is less than a inch tall from the flange.. the C6 LS2 pan is almost 1.5 inches..
Old 06-30-2006, 05:30 PM
Moderator
John B's Avatar
Steve, please size them to less than 100kb and post them directly here as an attachment. If you can't, please e-mail them to me and I will resize and post, thanks!
P.S. Please read your e-mail!!! I e-mailed you two weeks about on a particular subject (I PM'd you first) then you specifically told me to e-mail you because "you always read your e-mail"!!!
Old 07-17-2006, 09:39 PM
frijolee's Avatar
Still looking for this!
Old 09-05-2006, 06:10 AM
Davy_Baby9's Avatar
I thought the LS2 vette pan is the flatest you could find. Us s10 swap guys keep reading that the 5.3L oil pan was the best fit. But I also keep reading that the LS2 vette pan is a better fit.
I'm going to stay here.
Quick Reply: LS7 oil pan compared to F-body oil pan
