custom motor mount bushing material
anyone ever make thier own motor mounts and use some sort of ghetto but functional bushing?
were about to start on my freinds 240sx ls1 (the ls13v2.0) and ill be making everything from scratch as im not a fan of cutting holes in hoods for a s13, but im also not a fan of hardmounting aluminum blocks in a car that will be getting a lot of drivetrain abuse...
ive heard hockey pucks work great, does anyone have any other suggestions, or testimony to the hockey puck?
thanks in advance
thanks in advance
$2.00 each from Rock Auto, you can get a '75 Caprice trans mount. They have a two hole mounting flange and a single stud on the top side. That's $4.00 for two of them. Can't get much ghetto cheaper than that........
Andy1
Andy1
I used some sort of Jeep mount for mine mounted to one that was supposed to be a solid mount for a gen 1 small block. I fabbed everything up from my cross member. works great!
Dave
Dave
thanks in advance
thanks in advance
http://carshop.carshopinc.com/produc...1037a21d8ee486
If you want to go with a biscuit type motor mount, simply get the LS6/LS2 Corvette aluminum pedestals (often found on Ebay). Trans-Dapt has biscuits available from Summit for $26.
Andy1
Andy1
