More pics of my LS1 Coupe.
Old 01-09-2007, 10:19 PM
Vcious04's Avatar
Default More pics of my LS1 Coupe.
Just thought I would share. It is still pretty dirty and needs to be lowered more. Dang thing is too light and hardly compresses the suspension.
Old 01-10-2007, 04:01 AM
LS FUN's Avatar
Wow, looks nice. How did the swap go? Did the car start out with a 302 or the 4 cylinder? I have always loved the idea of a fox body with a LS1
Old 01-10-2007, 06:53 AM
LS1GMCTruck's Avatar
Default Nice Work
Nice installation. Would lowering the rear of the car a few inches help in preloading the suspension & weight tranfer? Gar
Old 01-10-2007, 07:32 AM
Vcious04's Avatar
Thanks man, It is originally a 5.0 car. The swap was actually pretty simple. Headers suck, but other than that, it was pretty easy.
Old 01-10-2007, 07:34 AM
Vcious04's Avatar
Thanks, Yeah, I really thought it would sit lower in the rear than what it does. I am using moroso trick rear springs with lakewood 50/50's. I will be dropping it about 1-1.5" in the rear.
Old 01-16-2007, 01:25 PM
69blackwidow's Avatar
what car is the upper rad hose off of. is that a gates hose mike
Old 01-16-2007, 01:30 PM
Darracq's Avatar
Looks nice, Ever tried those tires before just wondering how the hook compared to mt drag radial and et streets.
Old 01-16-2007, 02:11 PM
Vcious04's Avatar
Believe it or not the radiator and hoses are both for a 99 Z28 and fit perfect. Yes, gates. I fabbed up a set of upper radiator mounts and cut some notch's in the upper core support for the radiator cap, but thats it.
Old 01-16-2007, 02:12 PM
Vcious04's Avatar
Thanks man.. Nah, not yet but I am hoping they hook good enough to hang the front runners in the air a little.
Old 01-16-2007, 02:58 PM
Darracq's Avatar
I bet it will
Old 01-16-2007, 07:41 PM
PRAY HRD's Avatar
it looks like your motor is right up by the firewall? wish mine was. i think the guy that built it let the headers dictate where the motor was going to sit. there's enough room to have a picnic between my motor & firewall!
Old 01-16-2007, 07:51 PM
motorbuilt's Avatar
What headers did you use on it?
Old 01-16-2007, 07:52 PM
vanilla89's Avatar
what k-member and motor mounts do you have?
i have 1/8 inch between the pass head and the firewall
Old 01-16-2007, 08:15 PM
PRAY HRD's Avatar
it's got a PA sbc/fox k-member and i have at least 4", maybe 6"! i'm just going by memory, but that's pretty much close to it i think. motor mounts are 3 pcs of 1/4" steel plates. 1 to the block, 1 to the mount pad, & the 1 in the middle for as a spacer for the bolt heads that go to the block. no welding at all.
Old 01-16-2007, 08:35 PM
vanilla89's Avatar
that k-member puts a sbc in the same location as the stock 5.0 which is about 4inches from the firewall
i have a qa1 k-member for a 96-04,and it set it all the way back,it couldn't go back any more
Old 01-16-2007, 08:41 PM
PRAY HRD's Avatar
that's gotta be a LOT better for weight transfer. of course, if i get traction it'll help keep the front end down i guess. but it makes traction on the street worse being that much further forward. oh well, i'm gonna be trying to fit the MT 325/50 DR's in a couple months and see if they help. of course, i'm also going from 3.27's to 4.56's, so that wont help at all on the street. lol. but it'll be fun trying!
Old 01-16-2007, 09:52 PM
CobraSpdRH's Avatar
How are you liking that carb setup, I am going to be buying that Edelbrock setup for my S10 and was curious to see what others thought. It looks sweet
Old 01-16-2007, 10:07 PM
JRracing's Avatar
It looks like it should be fast. LOL.
Old 01-16-2007, 11:22 PM
tirefryin_s10's Avatar
you will love the carb .. my proform worked awesome on my car before going ls power , you wont get that thing through tech with all that rubber hose ........ car looks like a blast i plan to build one very similar in the future
Old 01-16-2007, 11:34 PM
2000LS1TA's Avatar
That's gonna be one fun car
Quick Reply: More pics of my LS1 Coupe.
