D&D T56 mated to a LSX
Edit: I'm suspecting it'll bolt up but you may need an extended pilot bearing like as if you were running an older style trans. LS bellhousing is only off by a bolt.
Edit: The extended bushing is no problem Mcleod and GM both make one.
Get a GM 621 Bellhousing $200.00
Mcleod adaptor flywheel $400.00
Adaptor pilot bushing $40.00
I can reuse my Centerforce DF clutch and factory z-bar set-up.
But if I can use a Camaro LS bellhousing:
Used bellhousing $??
Used flywheel $??
Dont know if I can re-use my clutch on any LS series flywheels?
Convert the car to hydraulic clutch $400.
Did I mention this is so much fun?
