5.3 fuel rail with return
You can also see in the picture where the regulator vacuum line is connected in the picture above.
Good luck,
id highly recomend you step-up to a 3/8 line on the fuel, a 5/16 id think would cause you to run lean..... and id get the push lock connectors (if you can find them) or get a 5/16 hard line to -6 fitting (for the return side) and a 3/8 to -6 (on the feed side).....then somewhere in the feed line before the fuel rail and after the fuel pump, install a fuel filter.....its not all that hard, but the fittings can be a bit confuseing....if you have anymore ?s just ask or PM me and ill help ya out the best i can.
This is the one we use.
https://www.summitracing.com/ga/part...iew/?rrec=true
